Hi all,
Further to the successful WA "group" buy of cam gears from a Japanese supplier in the past, I thought I might test the waters to see if those people who missed out last time would like to create another one. I'm looking at purchasing an exhaust cam gear anyway so if I can save myself and other people a few dollars with a group buy, I may as well try and get one happening. I haven't spoken with the supplier yet but the Trust gears as advertised at 13,300 yen + shipping. I think from memory Adrian managed to get this down to 12,500 + shipping which worked out to be about $200 each landed.
Long story short, if you are interested in a group buy, let me know!
Cheers!
Dave:D
BTW: I'm posting this as WA only as it will work out better on the shipping (where the real savings lie in group buys)
I would highly recommend editing the "supplier's" name from the first post.
for obvious reasons he's a bit camera/fame shy, at least on bulletin boards.
count me in on one rb25det r33 exhaust wheel.
john - small gains in actual power (5 to 10 kw), but it does enable some shifting of the power curve towards the lower revs. which improves driveability.
also makes a huge difference if you have cams, apparently.
most of the guys last time put them in themselves, but I think you might need to ask someone with a dyno to adjust it for you properly.
Strichline I can't help but noticing that i think your avatar was modified in Photoshop to put a bit of white smoke in ??
I do rememeber when racing you at the plex that you drove around the skid pad :bahaha: :bahaha:
Only 32's can produce the real thing :P
Steve-SST:
Curious as to why you've chosen to stock US made gears rather than the proven Jap gears, especially considering it's a japanese engine. I would think convincing people away from the "brand name" japanese items would be harder than simply stocking them in the first place. Saying that, I think the Wolf 3D system you sell is a sign of changing times away from the once "only true choice" being the Power FC.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
