A couple of the big powered LS1 guys i know launch in second every now and then. Shouldn't be that bad, however maybe being an AWD, it'll put a lot more load on the drivetrain compared to RWD so not sure...
Edited by PM-R33
wouldnt the box break first? also do they really do it? because one of the coments made by them was every gtr owner knows to lanch it in 2nd and they got a wicked start the guy in the 32 gtr got belted he lanched in first.
did they have traction?
when i think of hitting the plex and launching beyond 4000rpm all i can see is things ending with sideways into concrete
For best results, launch in 3rd
If you have the budget to build a car that can withstand that kind of punishment, then do it. If not, then do it and break shit everywhere.
Why not just make some more power, launch it gently, then munch everyone in 50m time?
Hahaha yeah i got that pic. Wasn't it the flywheel that exploded though?
yeh was the flywheel went everywhere even into the road was holes through the bonnet just a mess.
http://www.youtube.com/watch?v=g1KogYWDYrI
ok thats the battle but dosnt have the end bit where there talking and descussing the gtr's and about the lanch in 2nd i have the full dvd, now check out the lanch the r33 and r34 was in 2nd and the r32 and r35 where in first.
you are right. the big drama will be the strain on the clutch and on the engine. but sure its worth a try if you find you are getting lots of wheel spin in 1st gear launches. you'll need some decent power to get it happening nicely though.
crikey... the 32 initially gets off the line a touch quicker but the 33 and 34 come storming past... the 34 looks to be making more than 600ps tho... or its just running average tires as it smokes them up even launching in 2nd!? (maybe it was just turning the wheel as he had to steer around the 33)
I'd be interested to know if that improves the 0-100kn/h time as you wouldn't have to make a gear change
I'm too scared to try it... someone else try it and let me know how it went lol
Did any of you see the pic from a few years back where some muppet in a R33 ( I think), tried to launch it at 7000rpm and parts of the clutch came through the bellhousing into the cabin? Was pretty dramatic lol.
that was benm your talking about yeah... as far as i can remember it was a jim berry rebuilt clutch mated to a lightened stock flywheel and was a 1st gear 7k sidestep ~> BANG!
dangerous, dangerous shit
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
