Hey All,
I am now thicking of rebuilding my 2.6 to a 2.8.
My current specs are in the thread below:
http://www.skylinesaustralia.com/forums/Ch...up-t265663.html
Can anyone out there with personal experience see that the upgrade will be a smooth one (i.e. I'll only need crank, piston and rods).
Correct me if I am wrong please.
:P
https://www.sau.com.au/forums/topic/265671-rb26-to-28/
he is already running an 87mm bore. Just needs to change the stroke to 77.7mm by replacing the crank, rods and pistons. Will run fine, but prepare to fork out a fair bit of dosh - all the stroker kits are not cheap.
the only shopping part missing is an N1 block which isn't strictly necissary, but if your going to spend $8k or something on a stroker kit, an extra ~$3K on an N1 block is not unreasonable to do.
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4536895
I have not done it myself but here are some specs to give you an idea.
I think it's going to be a big job...
- http://www.nengun.com/hks/stroker-kit-niss...-28l-step-1-2-3
The HKS RB26DETT 2.8L kit is specially designed for Nissan's RB26DETT engine.
This kit provides improvements in torque during low to medium speed as required in street driving .
This kit also provides high horsepower output coupled with low frictional losses required for drag racing.
Extensive testing was performed in HKS.
HKS 2.8L Kit Step 1 Rated 441kW(600ps)
Compression ratio (Gasket Size)
* 8.70 (t=1.2mm)
* 8.4 (t=1.6mm)
* 8.1 (t=2.0mm)
Parts Included
- Forged piston kit
- Fully forged & balanced counter crankshaft.
-H cross section connecting rods.
* To cylinder block and baffle plate et cetera
Escaping processing becomes necessary.
HKS 2.8L Kit Step 2 Rated 588kW(800ps)
* 8.70 (t=1.2mm)
* 8.4 (t=1.6mm)
* 8.1 (t=2.0mm)
- Forged piston kit (nickel plated & piston surface has a final molybdenum coating).
HKS 2.8L Kit Step 3 Rated 882kW(1200ps)
* 8.70 (t=1.2mm)
* 8.4 (t=1.6mm)
* 8.1 (t=2.0mm)
- H cross section connecting rods.
PISTONS
Piston material is specially forged to HKS specifications. This ensures high strength, durability, reliability, and produced to high dimensional accuracy. As a result, this forged piston enjoys tremendous weight savings, and a well balanced part.
The piston crown has a balanced & symetrical concave section design which ensures higher engine response. Any larger concave section will result in a drop in compression ratio, and will affect engine response.
To reduce abrasion resistance, and to improve performance, the top piston ring is titanium coated.
In order to acheive an overall low piston height, piston design with two thin piston oil rings is adopted by HKS. This ensures minimum friction, and a low tension type piston.
CONNECTION ROD
With the use of high pressure forging for the material, the part does not requires much secondary operations except for the mating bearing surfaces.
High tensile bolts are used to prevent cap opening during high inertial forces generated at high RPM loads.
CRANKSHAFT
The strength of the crankshaft is ensured when the metal fiber flow is not affected during the forging process.
It is a full counter form, balanced to high tolerances where smooth revolutions are ensured. This results in loads being evenly distributed onto the metal surface, and reduces frictional loads.
It is extremely light and strong compared to the factory item, and other aftermarket performance crankshaft available in the market
The rigidity of the pin side is improved with the addition of a rib to the connecting rod pin.
The crankshaft manufacturing process is completed with a special hardening process according to HKS specifications to ensure increased reliability at high RPM loads, and reduce fatigue.
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4536930
frankly, if you are going to be stoking the motor, spending 3k on an N1 block in my opinion is not worth it since you are taking out a lot of meat out of the block due to the bigger internals. N1 blocks are perfect for motors built with larger pistons and thats about it. The whole point of going an N1 block is its strength, when you start boring it out your losing that strength and for 3k, thats a lot of money when your not getting its full moneys worth!
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4537063
true, but when your boring out any block you need all the strength you can get. The improved water channels in the N1 block allow it to cope with the thinner walls better. You can bore N1 blocks out to 87.5 or 88 mm, whereas standard block can't go any further than 87.
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4537094
in fact, if i remember correctly the tomei 2.8ltr stroker kit calls for an 87.5 mm bore which means you HAVE to have an N1 block to do it. Certainly all of the 3ltr strokers require an N1 block as they use 88mm bores.
edit: just checked and tomei provide options for 86.5, 87 and 87.5 mm bores.. presumable they modify the stroke to give the same displacement or just advertise it as an 2.8 ltr when it ranges from 2750cc - 2820cc depending on bore size.
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4537096
a lot more custom work involved in dropping it in a gtr chassis, especially if you want to keep the 4wd too i would imagine.. i have heard that its not as easy as one would think...
In Sydney, 3k covers motor out, rb30 motor in, all mounts fabbed up, fluids etc, ready to drive away. Compare that to the price for an RB26 out and an RB26 in :)
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4537141
well rb26 out and in roughly would cost 1600 approx... plus, there are a lot of well built rb26's out there putting out a lot of power, just need the right set up/formula to put the right parts all together to make it good!
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4537156
Im working on an open deck engine project at the moment that might interest you. Basicly with my design there you could use and RB26 or RB30 crank as the base, and with modifications achieve a 2783cc capacity with the 87mm bore and 26 crank, or 3175cc with the RB30 crank (87mm bore). Both are high deck built in an RB26 block, long rod setups, sleeved blocks etc. The 3.2lt is 22mm taller than stock, and the 2.8lt is 12mm taller than stock. I hope to have a prototype engine in my R34 inside 3 months. Because im using a standard crank or rb30 crank as the basis and the rest is machining its a lot cheaper than a HKS kit and provides more capacity too.
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4537281
The Tomei 2.8 kit into a 26 block is pretty much a bolt in job, you can get them with 86.5mm pistons as well, no need to go for a big bore. I did one late last year and there are no hassles doing it, just need to check and make sure there is enough clearance between the rods & bottom of the bore etc.. They supply spacers for the oil squirters and really good instructions if you read Japanese. It's still worth checking the balance on the Tomei kit though.
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4537366
easiest and best option would be to sell your current built bottom end and buy a n1 block and hks kit and put it in once done, u would be crazy to pull yours apart and do everything again when u could just sell it as a bottom end ready to go.
I like that option. :D
https://www.sau.com.au/forums/topic/265671-rb26-to-28/#findComment-4538354
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
