Are there any lips for the R34 GTT frontbar other than the Eastbear ? I really want to fix up my frontbar height as it just looks weird now with too much clearance... Ideally I want something no bigger than 3-4cm TOPS that just attaches to the factory frontbar.
The eastbear lip/diffuser is 7-8cm so its way too big and it costs $900 so no go. I've seen a couple of GTTs before with front lips on stock bars but have no idea what they were. Something like just the bottom half of the Eastbear lip (the diffuser part) would be excellent. Don't wanna change the whole frontbar either as I like my factory frontbar (looks good AND its proper plastic)
https://www.sau.com.au/forums/topic/265828-r34-gtt-lip/
yeah I've seen that nissan optional lip .. doesn't really do it for me TBH. One of the big Skyline traders in Sydney that was doing some paintwork for me had one in stock and offered it to me for $500 painted/fitted iirc..
Have you got any more pics of the car taken during the day with normal lighting ? Cheers
Edited by Delta Force
https://www.sau.com.au/forums/topic/265828-r34-gtt-lip/#findComment-4542026
Hey mate, could you PM the traders details about the lip to me? I've been looking for one for ages now. Thanks mate!
Edited by JI34GT
https://www.sau.com.au/forums/topic/265828-r34-gtt-lip/#findComment-4542694
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
