Guys/Girls,
Anyone know where i can borrow a Tap and Die set from like now or early tomorow?????
when i put my steering wheel on about a year ago i cross threaded the 19/18mm nut that holds it on to the steering column... never bothered to fix it until i got bored today and took it off (was originally too scared cause it wouldnt come off at all...) and now i want to put it back on before tomorows race... anyone know anyone with one i can borow for about 20mins???
https://www.sau.com.au/forums/topic/26583-energency-need-help-urgently/
Damn it, if only you tell me a bit early would have been good. I work at WURTH AUST so things like that is easy fix but i just got home from work and as you know i'm having tomorow off as well so ....can't just turn up tomorow at work for something then leave !
well ur racing so u only need to go straight
get the car towed there, then just race and have a shifter holding onto the steering thing or something
your gonna lose anyway arent you? wasnt that the plan?
p.s: buy a puppy
ha ha, I was actually starting to think "tap and die" was a metaphor:
tap the accelerator and the car dies
tap the accelerator and turbo dies etc
or
tap into the race and die of embarassment...
I will stop there :D
stfu gordon!! wheres ur car again? no not the clapped out ford.
dont worry it will be fine to get there and back i just wanted to finally fix something thats been bugging me for a year... but not enough for me to bother fixing rofl.
new forcast now... looks like its going to be windy with SOME showers.... so it should be good to go!!
seriously though Ni - throw in some teflon tape for good measure!
And good luck with the race - hopefully it happens this time :D
Regardless of who wins, you will have fun and hopefully crack some nice times too.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
