Not sure if you guys have seen it yet, so here ya go. Personally i love it, but i can understand why people would hate the styling. You gotta admit, it looks tuff as f**k!
http://www.caradvice.com.au/28917/lamborgh...pyder-revealed/
https://www.sau.com.au/forums/topic/265871-new-lamborghini-reventon-spyder/
sorry..........FAIL
you know....this is like ferrari saying........we're gonna do a Enzo FXX in rag top.
Reventon hard top gets the thumbs up
Reventon no top .....well, I fart in that thing's general direction.
if there anything like the first reventon (very few made) u have to be invited to buy one first so expect the first half of them to end up in dubai and abu dabi lol
I swear they make them because they know Jay Leno will buy one and prince Sheikh Mohammed of UAE will buy the rest lol.
Awesome car... looks likes a Batman car. He should have used this in Dark Knight lol
It reminds me a lot of the old Countach, not really a fan. If I had to go Lambo it'd be a Muira.....
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
