Welll well well
was feeling all fine after recent tuneup, gave her a service myself new plugs etc.
driving home last night going up the expressway hill I had heaps of bad surging (1psi) couldnt boost anywhere near asper normal, and black smoke billlllowing out the exhaust (on boost only)
felt bad, climbed up off boost in left lane.
today driving, same thing. boost is bad (wound down the ebc to .3bar) as soon as it hits 1psi - 3psi it is surging, airflow is all turbulent, and the turbo sounds like its working its head off (not squealing, just 110% load), lots of black gooky smoke and just generally bad bad.
So, it seems my turbo oil seals are farked. When the head was being worked, the tomei oil restrictor in the head meant there is more pressure going thru the turbo line, hence boostwerks said they fitted a better flowing oil restrictor to the Sliding Performance 360degree thrust bearing nissan r33 stock highflow turbocharger, steel wheels with ported housings.
Seeing this had happened previously (ie a few months ago at the garage) Im guessing that would have had an effect on the journal bearings. And now she's starting to die.
An untimely death, but perhaps timely.
You see Im doing a project, twin turbo manifold with twin stock nissan ball bearing highflow's.
Untimely in the fact i cant afford to do 2 at the moment, nor the manifold. However I have already received the new Garrett Ball bearing for the core $140 and paid $99 for a new comp.wheel/turbine shaft set.
thats $239 usd all up, will rebuild and spend some cash on a rebalance at a turbo place like ATS.
However Ive got another dead turbo here kindly donated, and will rebore the housings of this one out at my pops place, and eventually order another bb core and turbine/comp.wheel set, rebuild the donated turbo.
Its just going to take a while before I'll have the funds to do it all, due to intake fabrication required and exhaust manifold and work to flow two dump pipes into one (same with intake, same with charged air to the cooler, need 3x Y pipes)
bad luck that the turbo has started to fail just now (-600 on my visa is all I have got to my name) but good luck that I was already ordering parts.
now back to ripping apart the donated turbo to see what else I may need via a rebuild kit.
oily black smoke on boost = turbo dieing. 20,000kms old, never went past 1.09 bar, but it was only $600 3.5yrs ago plus a dead turbo. Not too bad, seeing now I can make it Ball bearing. Not sure if the 16G compressor wheel will be ok, nor if the TD05H turbine shaft will fit ok. If not its $100 for a Garrett 60-1 comp.wheel and $170 for the turbine shaft. trying the cheaper way 1st. fingers X'd
https://www.sau.com.au/forums/topic/266025-pffft-and-there-goes-my-turbo/
  • Replies 78
Posted Images
You 100% sure it's not IC piping? Steve had this same issue on his car, turned out there was a crack in one of the silicon joiners. Check that just in case, you never know
Will do. letting the car cool down right atm, and will spend some time going over everything, put it up on the stands and search, but perhaps I'll start anyway to pull bits off this week.
get to the turbo and have a good look. Just takes me time with no knees and lots of pain, so slow going but have to do it. Stag is coming off the road :blink:
not a problem, cheers tho.
none of the cooler pipes down low look out of place
tomorrow will inspect everything.. not enough light now.
100% sure its not IC tho, felt ic-issues before but this seems different..... want to see the shaft(s) of the turbo.
if its black its fuel dude dont stress, unless just your rear wheel fell off, ive seen a seal go before and its pure white just oil in the exhaust!
ah 'k
cheers for the replies and ideas
will check over in the morning and sort thru it all.
yeah Brendan ive done 2x 90 degree pipes now the 2nd one made me shit my dacks as i thought i blew the turbo even got a tow home from luke to find out we could of fixed it there and then
and i couldn't see the split either till i putted it off
ah ok
hoping its that then.......
will see tomorrow
cheers
cheers ken & andy
tis' ok tho, pulled the pipes off everything to the turbo, cleaned afm pod etc, touch of oil as one pipe gets closer to the turbo (pre-intercooler)
oil all around the underside of the compressor and around the compressor housing, looks like oil seal to me
:P
no shaft play to speak off, comp.wheel and intake look really good nick, so says to me its inside the turbo, oil seal...
will take off the dump and drop the turbo from the manifold shortly, slow-drain the fluids.
all ic-pipes look and feel ok for leaks; definately turbo / oil related.
it isnt the turbo
now looks to me like its from the engine
bottom end may be going, cant tell, but here's hoping its just the oil pump then.
anyone down south have a compression kit available to lend out?
I should buy one but cant till this thursday (disabled pension fyi Kralster, feeding 4 ppl and a morgage on 400pf isnt easy dude)
around $50 for a basic compression testing kit but put my last 50 yesterday into petrol lol !
so. all in all, I now think its the engine NOT the turbocharger
hey sorry wasn't trying to be rude or anything, sorry if i sounded like a dick.
Just borrow a compression kit if you can, that 50 bucks can be better spent on your family. I'm sure someone here can help you out.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
