  • Replies 78
Posted Images
the turbo is pretty insane
2500rpm and its wanting to get into positive boost, 3000rpm and 10psi is up
3500rpm and 16psi is up
wow
set up the ebc for 13psi and 16psi
just want to be safe with the safc/sitc/remap and so far so good.
running really well and pulls significantly harder than what Id imagined it would.
are you running a aftermarket computer?????
standard computer just tweaking his SAFC and SITC
With that turbo you will max out your standard AFM under 1BAR and you will also run out of adjustment with your SAFC once you fit the bigger AFM and injectors you will need to get anything like the most out of it, after all it is rated to 460hp
Edited by D_Stirls
i think you will find that he has been mislead to a certain degree and its nothing more the a bb high flow.
it certainly isnt the same as the graph you have posted due to the nissan front and rear housings been used.
that graph is for a complete gt30 with garret front and rear.
as DP03 mentioned in FI its not a true gt30 core cause it has a 7 / 14 comp wheel,
thats why i was curious as to what the id tag says.
ID tag was posted in that FI thread.
Front nissan housing and perhaps AVO .63 rear housing?
fact is Im happy with the bolt on turbo upgrade. definitely a top turbo
garrett plate:
IMM 120880
700177-3013
talking to discopotatoe via pm turns out its a GT30 / T04S 60T cartridge, avo .73 rear housing, ported 45v4 front housing
http://www.youtube.com/watch?v=LNQU-tVSuw4
239rwkw
oh yeah
1997 Series 1 Nissan Stagea RS V Four Station Wagon, 106,500kms, Auto, RB25DET engine, Attessa 4wd, Silky Snow Pearl, Dayz bodykit,
Fresh fluid throughout,
Engine:
Ryco Z201 fuel filter, Ryco Z145 oil filter, Ryco Z160 turbo oil filter
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic shift kit & auto service kit
Koyo Radiator upgrade
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Greddy remote oil filter relocation kit & Fujimoto sump plug drain valve
Garrett turbo oil return filter relocation adapter kit with oil pressure & temperature sensors
Catch can kit
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system (turbo to cat)
3inch high-flow metal race cat
3inch cat-back exhaust system with Magnaflow 4" barrel mid-muffler & Kakimoto GTR Racing rear-muffler
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Trust 600x400mm FMIC bar & plate, with custom hard pipe kit
Apexi power intake pod filter, with custom hard pipe feed & hard pipe intake to turbo
HKS heavy duty turbo actuator
Garrett GT30/T04S 700177-3 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
Ported & Machined headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
Cometic head gasket 87mm x1.2mm
ARP head stud kit
Aerospeed adjustable exhaust cam gear pulley wheel
Tomei 256 intake / 256 exhaust poncam gear set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar, custom boot swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphite 17inch rims with Marshal Mactrac TX tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit & car alarm
Interior:
Ghepardo reclining racing seat
Flynn racing seat rail
3x 2" DIN gauge setup including boost pressure, oil pressure & oil temperature
Apexi electronic boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 0.9bar and 1.1bar
Toshi ecu remap, tuned by Boostwerx
239rwkw
will get an air/fuel ratio & injector duty update next week
cheers darren, last tune was 206kw so she's gained roughly 17% power
worlds apart in terms of oooomph. gets up 'n boogies
hey CUBES how in the hell are ya ?
great power from the auto for sure, cheers
I reckon I can up the boost, seeing she's got the headgasket etc
1.3bar?
hey dean, yeah no worries, let me know when...
nigel yeah everything is as stock but modified for higher values, ie fueling setup for a big pump, z32 afm written in, airflow values setup for a HKS2540, etc
so yes VCT is working just dandy thank you very much :)
had a quick drive a 3am (couldnt sleep), very very quick :(
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
