  • Replies 356
Hi Guys
I won't be making it tomorrow will have to get to the next meet.
Had the M35 in for a drive line vibration found it to be universal joint. Not replaceable. So Having tail shaft modified to enable fitment of replacable universal joint.
Have fun.
Murray
Hi Guys
Have fun.
Murray
Spewing, hopeful it won't cost too much and won't be off the road too long.
If this meet goes well we will have to do something every 3 months or something.
Out of interest how many km's has your M35 done? Just wondering if it's distance or hard driving that has caused the problem, that's the first time I've heard of anyone with a universal joint problem since I brought my M35 (February 09).
so wot we doin are we meeting sum where and cruisin there or just meetin onsite .ill bring a few snags and a loaf of bread
Depends where you are coming from, there is a small group of us meeting on Abbott Road, Seven Hills (Opposite Macca's & BP) around 2pm for departure about 2.30pm, going to Rhodes via the M2 motorway.
If this suits, your more than welcome to join us.
I probably won't bring any food but will have 20 copies of FAST 2009 JDM so anyone who gets a copy has to throw me a bread crumb :D
I've got FAST, but not the 2009....so i think ill have to trade you some sausages....i will also have bacon and eggs :)
Man im at fkn work n i dont finish til 1 :D
Anyone wanna come wash mine for me? Preferably women in bikini's???
im doin mine now but id be happy to supervise the bikini washers at your place lol
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
