umm mines a GTS, so it idels at 500 rpm, around 1000 with aircon and demist on.
I use BP Ultimate. I tired Optimax, but my exhaust kept givin off this godawful sulphur smell.
BTW b4 u post athread next time, search there's been about 6 threads already and 1 poll about which fuel ppl use.
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-562770
I have only, do only and will only ever, use Mobil Synergy 8000. Sure it gets a little pricey sometimes but someone once told me that was the one to use for my Skyline. And when he talks Liners, I listen.
I think it all comes down to preference tho. I'm not sure there is a "perfect" fuel to use.
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-562976
I was reading a big write up on the quality of fuels in Australia and it had some VERY interesting info in it. Personally I only user Optimax but once my new car arrives I wont be using it anymore. It turns out of Vortex, Optimax, BP Ultimate and Synergy 8000 that only two of these fuels have a true 98RON level - Optimax and BP Ultimate. It is even stated on Mobil and Caltex's web sites that their high grade fuel ranges between 95 to 97 and that’s piss poor!
Another thing I found was that BP Ultimate is a higher grade fuel than Optimax due to the fact they add additives to Optimax to get it high octane levels where as BP is brewed that way and has less aromatics than Optimax. Interesting hey!
As for higher grade fuels - Elf LMS. This stuff is shit hot and can provide up to a 30rwk gain in power in cars like Skylines etc. LMS is available in either 200 liter or 50 liter drums. Price: $4.85 per liter (200litre drum), $5.30 per liter (50litre drum).
As LMS is an unleaded fuel, no CAMS license is required to purchase the fuel only problem is as you can see it’s pricey but well worth it for a day at the drags. Should get a few runs with a 50 liter drum :P
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563224
some of the 'better' octane boosters do provide up to 2.0 points increase. Nulon Pro Strength gave I think about 1.7 in a HPI test a couple of years back and for about $12-15 was the best buy in that dept [octane booster dept].
Adz: Strangely enough I think I find Synergy gives me a smoother idle than BP...strange.
Ward: in terms of price I dont find synergy any dearer than ultimate in my area, they are both around 7 cents dearer than regular unleaded, whilst optimax is approx 8.5 cents dearer...
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563311
Ahhhh I stand corrected. But as you said some of the "better" octane boosters have a decent increase, not all :P
As for the idle I honestly dont know. The information I have is written info form the makers of the fuel, maybe Mobile does idle better?
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563327
thats cool, I wasnt really asking a question about it, I was just stating that because mobil seems to be an inferior fuel [in terms of octane at least] I am surprised it seems to feel smoother in my car as compared to ultimate...I still use ultimate because of the octane level :P
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563345
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
