Reading Nissan ECU Fault Codes,
now this post is going to explain to you in 15 minutes that took me days on end to work out searching through hundreds of websites and pages ripping out my hair nearly. due to my skyline running like an old morris minor running on three cylinders and using buckets of petrol just to go to the shop to get smokes damm it, and the gearbox which is an auto was doing random things it had'nt done before, so as i did'nt want to spend any money diagnosing these problems due to the amount you can spend putting these little jiggers on a dyno, So i started thinking back to my old sss pulsar days when you would just pull out a plug leading from the little black box under the passengers seat, grab a piece of wire and just bridge two of the ports and the error codes would just flash out on the check engine light on the dash! So after finding a post on the net about the skyline codes, I read you just take of the kick panel on the passenger side floor undo a few nuts and remove the Ecu and look for one or two led's and a small screw you can turn clockwise and anti clockwise to make the codes function for you now if this relates to your ECU here are a few links I found all about these types of ecu's http://forums.gtrcanada.com/showthread.php?t=13657 , http://www.nissanforums.com/truck-suv/8483...rror-codes.html .
which is not what im writing about here as my ECU is an genuine Aftermarket type which does not have the two led's or small adjusting screw so where too from here I thought then after sifting through tonnes of info i came up with the theory below which takes three minutes to diagnose and clear all faults to reset computer which = top performance!!! so read on below and see how you go with this you will be suprised and you don't even need to touch the ecu behind the passengers kick panel and best of all it's free. oh besides the paper clip haha!! Check (if you live in usa): Kroger Weekly Ad, or Myer catalogue.
Reading Nissan Fault Codes
Nissan ECU's allow you to read any stored fault codes without any specialist equipment.
Below will show how you can read yours. The orientation of the plug may vary so please make sure you are looking at the plug the right way up before you try this on your car.
First of all you need to obtain the consult diagnostic plug location. This us usually in the same area as the fuse box. located drivers side near right knee under dashboard.
Below is a typical example of what you are looking for.
Once you have located the consult plug you then need to grab yourself a short piece of wire or a paper clip.
Please read all the following instructions in full before you attempt to carry a fault code read out.
  1. Switch the ignition to the ON position but do not start the car.
  2. Depending on its orientation of the consult plug (see below) bridge the two lower left, or upper right pins on the consult plug with the wire paper clip for 2 seconds then remove the bridge.
  4. Observe and write down the sequence of flashed produced by the engine check light on the dash. using the information provided above.
  5. Once you are satisfied you have all the fault codes bridge the consult pins again and this will erase any stored fault codes and revert the ECU back its normal operation.
Understanding the fault code readout:
ECU fault codes are usually displayed on the engine check light on the dash, and are displayed by the number of flashes as well as the speed of the flashes.
For example, an ECU showing no recorded faults will display code 55. The first digit is shown as 5 followed by a pause. This then followed by the second digit. This is shown as 5 short flashes. Thus Code 55 - all clear.
Listed below are the fault codes for the skyline
11 - Crank Angle Sensor/Camshaft Position Sensor
12 - Air Flow Meter
13 - Engine Coolant Temperature Sensor
14 - Vehicle Speed Sensor
21 - Ignition Signal
22 - Fuel Pump
23 - Idle Switch
24 - Throttle Valve Switch
25 - Idle Speed Control Valve
26 - Boost Pressure Sensor
27 -
28 - Cooling Fan Circuit
29 -
30 -
31 - ECM
32 - EGR Function
33 - Heated Oxygen Sensor
34 - Knock Sensor
35 - Exhaust Gas Temperature Sensor
36 - EGR Control-Back Pressure Transducer
37 - Knock Sensor
38 - Right hand bank Closed Loop (B2)
41 - Intake Air Temperature Sensor
42 - Fuel Temperature Sensor
43 - Throttle Position Sensor
45 - Injector Leak
47 - Crankshaft Position Sensor
51 - Injector Circuit
53 - Oxygen Sensor
54 - A/T Control
55 - No Malfunction
63 - No. 6 Cylinder Misfire
64 - No. 5 Cylinder Misfire
65 - No. 4 Cylinder Misfire
66 - No. 3 Cylinder Misfire
67 - No. 2 Cylinder Misfire
68 - No. 1 Cylinder Misfire
71 - Random Misfire
72 - TWC Function right hand bank
76 - Fuel Injection System Function right hand bank
77 - Rear Heated Oxygen Sensor Circuit
82 - Crankshaft Position Sensor
84 - Automatic Transmission Diagnostic Communication Line
87 - Canister Control Solenoid Valve Circuit
91 - Front Heated Oxygen Sensor Heater Circuit right hand bank
94 - TCC Solenoid Valve
95 - Crank Position Cog
98 - Engine Coolant Temperature Sensor
101 - Front Heated Oxygen Sensor Heater Circuit right hand bank
103 - Park/Neutral Position Switch Circuit
105 - EGR and EGR Canister Control Solenoid Valve Circuit
108 - Canister Purge Control Valve Circuit
111 - Inhibitor Switch
Check: Costco Weekly Ad
Check: Supercheap Auto Catalogue
112 - Automatic Transmission Speed Sensor
113 - Automatic Transmission 1st Signal
114 - Automatic Transmission 2nd Signal
115 - Automatic Transmission 3rd Signal
116 - Automatic Transmission 4th Signal
118 - Automatic Transmission Shift Solenoid Valve A
121 - Automatic Transmission Shift Solenoid Valve B
123 - Automatic Transmission Overrun Clutch Solenoid Valve
124 - Automatic Transmission TOR Conv Solenoid Valve
125 - Automatic Transmission Line Pressure Solenoid
126 - Automatic Transmission Throttle Position Sensor
127 - Automatic Transmission Engine Speed Signal
128 - Automatic Transmission Fluid Temperature Sensor
Important note:
Please take care if your going to carry out any such diagnostic procedure on your car and understand that this information is provided in good faith and we can accept no responsibility for any accidents, errors or inaccuracies should you decide to follow any of the information provided here. although it did work fine for me and after finding three fault codes and fixing them my skyline has never gone better. So good luck with this and just make sure you take caution when working out which ports to bridge i just faced mine upright and bridged the left hand botton two and it worked first shot.
  • Like 2
could you post the picture in a bigger size (including the surrounding) so I could understand which side is the top and bottom.
thanks
sure thing :P attached are some pics for you marked out, these pics are of the plug as if you are sitting in the drivers seat looking into the fuse box!!
  • Like 2
  • 1 month later...
checking a fault code is about a one or 2 minute procedure but its amazing the number of persons who post about engine not firing properly/missing problems who have never bothered to d/l the R34 Engine Service Manual from the internet or even to read it
  • 1 month later...
  • 2 months later...
very interesting! Never knew you could do that with the skylines. Majority of people just say look at the LED on the ecu but this seems much easier.
Should be in the tutorial/diy section
thanks! i know it is huh!! but you know what the funniest part is yet this is so simple to do once shown yet it took me about three years to actually find out how to do this!!! on my ecu there are no actual led's, so i had to improvise to get around it, i will post this up in diy thanks for the feedback much appreciated im hoping this has helped out many!! cheers
if the ecu has 2 fault codes
will it flash (for example) 4 pause 3 pause 6 pause 8?
show 2 fault codes??
or is it different?
yes thats right if there is 2 fault codes it will read them out one after the other example: code 23 and code 44 will read as 2 flashes pause 3 flashes pause 4 flashes pause 4 flashes them it will repeat and so on. so if you had say 9 faults it would read them all out one after the other in a row then repeat them so you really have to concentrate on it and let it read them out 3 or 4 times to be certain exactly which fault codes youj do have cheers
good point
  • 5 months later...
*coughs* yeah, sorry about that peoples. but got the ignition error code, so i guess coilpacks are the problem just as was suggested, reset the ecu as well and wow is it happier. response is so much better, and more power, it was very nice. however, having the ignition on "on" without the engine running for 5 mins resulted in my bro and i trying to bump start it up a hill for half an hour hahaha
  • 1 month later...
  • 4 months later...
sorry to bring up an old thread but i just got an a/t control error code (but my car is manual) and also knock sensor error? Does that mean my sensor is rooted or can i some how assess it without replacing it? I hear they are under the intake plenum and a mongrel to get to!
Also y would i get the at control code error if my car is manual, how do i fix it? Or get rid of the error code
Edited by THRLLR
  • 4 months later...
depends on the model, up to $420 delivered I think. Look through the misfire sticky if you want to try some other bandaid solutions first. Also, is it misfiring much? At higher rpm? Or just displaying the code?
Does the way the car runs change when the code error comes up?
Edited by Galois
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
