Click the link below or look in the EVENTS thread for more info.
If your not participating come and see what all the fuss is about.
You will also be able to join and become a member on the day if you like what you see.
Whats membership get you-Super cheap track days, Official cruises, Functions, etc etc, also you will gain 11ty KWATW, grow 6 inches and have girls/guys knocking your door down to bath in your awesomeness.
SAU NSW is a equal opportunity awesomeness.
Agreed on the awesomeness!!
Come on boys and girls, stop "cruising" hot spots and getting defected! Come to Wakefield!
You'll be surprised how much fun you'll have and you'll be impressed with how your skyline actually goes!!! Remember, theres no speed limit out there!!
ill take two if i can get this gtr to a dyno and make sure the mixtures are ok
[/quot
Come and play ya big fag,,,been a long time since we have seen your car control.
Some have never seen it.
Bring the almighty R31,,,I'll be happy to hand you your arse.
Neil.
if you had a seat in your car that could accomodate my arse i would love to show ya some car control
r31 is getting a bigger turbo (so off the road)
im looking forward to doing skidz and showing duncan how not to blow up a gtr
and becasue of this club campness ill even become a member to save ten bux
and jenna will to
lol
I will drag race you down the straight for a cookie Chris but the bets off as soon as we hit the corners.
MR Slip and Slide.(gotta get me some semis and camber, then the bet will be on again) LOL
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
