Hay guys, what do u get from 0-100kms? Mine's R33 GTST(Auto) from 0-100kms is 8.1 sec. How is the result for GTST, is my car in good condition or bad condition? Becasue my pervious GTS could get it within 10 Second(MT). So i just wonder is that result very bad for a turbo car?
Cheers
Steven
https://www.sau.com.au/forums/topic/26752-what-is-u-guys-got-from-0-100kms/
yeah mate i think so! So u think my car is on not too good condition? Becasue actually since i bought that car, no matter how hard i accleerate the car(Kick down), and i didn't feel the turbo is coming.( Becasue that is my first turbo car, and i never sit on a turbo car) So just wonder when the turbo is coming, how is it feel and how can i know when the turbo is coming?
I know in the Dash under the RMP in R33 have got a little clock, it like +7, and -7! And when accelerate hard it will raise. I wonder, when it will be raise to +7, becasue even i kick down , the maximum i could achieved was between +2 to +4 ! what is yours one guys. What do u guys got, if u kick down?
Cheers mate
Steven
i don't really understand what u mean. Sorry!
But i did shifting the gear manually, even from 0-100kms, started from 1-and 2 gear. And i also couldn't achieve +7.(Max i could go is +4- +5) If on the highway, i did push the O/D button and power button, then kick down from 70kms to 140kms. It also couldn't achieve it. Wonder why? is my car have problem or the turbo goes down?
Last thing is can you please tell me how does the turbo works?(Becasue it is my first turbo car) is it noticeable?
Thanks for the advice!
IC, thx bro! Make me so upset b4, i thought my turbo have something wrong. So if i want to achieve +7, then what can i do, please show me. Becasue i really feel my car even got the turbo, but it's not so powerful.
By the way, can u please tell me, how to determine the turbo and the engin is in good condition?
Cheers bro
pentae :P
steven dude "Becasue i really feel my car even got the turbo, but it's not so powerful."
that doesnt really make any sense :) surely you can find some one who knows a bit about these cars that can help you first hand! because i cant understand you bro!
to up your boost to get your +7 get a bleed valve fitted. very simple about 100$AUS. But factory boost gauges can be faulty, i had mine running 12psi, and the factory needle hardly moved into the +zone for some reason.
Thx dude, u know why i said like that bro? Because today i killed by one GTS25 on the traffic light. that's why i thought perhaps my turbo has something wrong or either my engine is in not good.
Because it's a long story. Since i bought that car, i need to repair lots of thing. But anyway, i really appreciate you guys the valuable advice.
cheers bro!
Cheers bro
The main question is y did u buy an auto for??
By stall it up i mean using your left foot ump on the brake hard so the car isnt going anywhere...then using your right foot apply some throttle.
The revs will climb ad the engine will start making boost, if you let go of the brake the car will kind of cataplut from the standing start. Try this method a few times, with different amounts of reves, even wheelspin to see the quickest way
I have an Auto and its fine. Just stall it up using the brake to about 2000rpm then plant it. If you want to go faster turn overdrive off so it rides out 3rd gear all the way. My 0-100 time is like 5.5 sec using the stall method. Make sure the power button is on so it will redline every gear and it should be better. And getting +4 on the stock boost is good probaly about 7psi (guess?).
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
