  • Replies 184
dammit. I probably wont be back to my house in Wantirna until 7PM by the time I get home from wrok. If I miss the meeting point at Mega mart / harvey norman is there any stop offs on the way that I can meet up with people or is it straight to the Pizzeria from there?
I'd say just go straight to the main meet point at the car park. We will all be there from around 8pm >_<
hi all
as per title... after all my handy work and that of a friends getting my headlights back to OEM Xenon, my right headlight just blew! >_<:down::laugh::P
D2R globes are getting on a bit these days (second hand ones at least) so the ones i've put in may have seen quite a few hours use.
i know this is an incredibly long shot, but if anyone has any D2R globes lying around, i'd happily taken 1 or some of your hands :)
was kinda keen on heading to the pizza cruise tonight...
shame little man missed out! shes my mrs now
does that mean i still get pizza?
>_<:laugh:
I knew you were keeping her to yourself! (Swaps for a GTR..?)
Yes you still get pizza.
On the same token you can shout me as it's my BDay to day!
:down:
no car Jezza ?
what happened to Kris ?
Transmission is being ghey. Dunno how reliable it is. Last thing I wanna do is break down in the rain with my targa roof leaking like it does >_<
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
