Hi Guys,
Need a bit of help on fuel pump setup..
I dont want to go surge tank so im looking for an intank pump that will be able to flow enough to pump out 350awkw roughly
will a bosch 023 do it?
Iv got all supporting mods, nismo FPR and sard 800cc injectors.
Opinions please? would rather hear from guys who have setups making this kind of power and what they used to get there.. Ideally i want to go more then 350awkw however i think that will require a turbo upgrade again...
Thanks
Mass
https://www.sau.com.au/forums/topic/267715-r34-gtr-power-output/
yeh iv already got the FPR from previous mods, now upgrading the injectors hence why i have an fpr and 800cc inj....
I was just a little hesitant with using the 044 intank.. Iv decided to drop in the 044, and yes iv got the -5's so im looking at pumping out 350.
One more question for those that know,
What do the stock AFM's run out of puff at?
Do i need to go for Z32's? i was looking at getting them but unsure as to wat the stockies flow awkw wise????
What boost are you gonna run Mass? Your still on stock internals like me, correct?
My set up is similar to yours but with different ECU. Ive got ~300AWKW at 1.2 Bar.
Im far from an expert but in the research I did, most people with 350AWKW upgraded their air flow metres to Z32s
I bet its at least x3 the cost of the 044.
I made 326 on 17psi with standard afms...you will require about 20psi to make 350odd, so depending on your tuner the afms may need upgrading.
I have a single Z32 afm and did make 380. Dont know how the tuner did it but he did...its all in the tune!!
hey guys,
thanks for the input so far....
Not stock internals anymore... engine is currently stripped and being built... its having the full treatment, forged internals, cams and sump etc.....
i was looking at a pfc d jetro instead of the Z32's but i think i might play it safe and just go Z32's with the pfc iv already got...
Only other thing i need to look at now is coil packs... tossing up between JJR and Splitfires??? not sure on the differences?
Hey guys, just a question out of curiosity as I begin stage 1 mods, but what are most of you running, 80mm or 90mm exhausts on your GTR's? I have an R34 GTR Nur with the N1 engine etc. Does the extra size really make that much difference in power?
Cheers,
Ed
Whats wrong with stock coil packs? Buy the HKS Twin Spark and you will have no issues!
Thanks guys....
As far as i know my coils are fine, not failing, but i dont want to throw it on the dyno up the boost and find its suffering coz of coils....
So i thought the JJR's are a good cheap alternative, however unsure on quality???
Dunno bout the HKS twin spark? wat is it?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
