Used parts:
6boost Steampipe manifold, high mount, T3 flange, external gate (only used for 2 months) $1000
Custom RB25 polished inlet plenum $650
Q45 throttle body $280
Z32 Air flow meter w/plug $250
ER34 RB25-NEO PowerFC + hand controller $1300
Denso 670cc injectors + rb25-neo fuel rail $950
Tomei type a poncams to suit RB25 neo $700
Splitfire Coilpacks DIS-008 $450
Carbon Fibre coilpack cover for RB25 neo $200
email [email protected]
https://www.sau.com.au/forums/topic/267738-rb-engine-parts-for-sale/
  • Replies 44
then the 260 degree in/ex 9.15mm lift are type b.
if thats definately consider them sold.
but only if 100% definate as you first stated as type a.
ive sent you an email...
consider the 260 cams sold so dibs for me.
ER34 RB25-NEO PowerFC + hand controller - SOLD pending payment confirmation
Tomei type a poncams to suit RB25 neo $700 - on hold pending payment
Splitfire Coilpacks DIS-008 $450 - on hold pending payment
hay buddy
do u still have the carbon fibre coil pack cover. if so conside it sold
pm me please
and could i have a pic of the plenum please buddy
cheers
julz
Edited by GUN_METAL_GTR32
plenum is fitted to NEO head. idle is fine, was tuned to idle at 850rpm, over 300kw. Has individual throttle "velocity stacks" inside and throttle response is great with a GT3540.
does it come complete to install, if not what is required?
thanks for your speedy response.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
