the rear spring seat is threaded for spring pre-load, and the damper also has a threaded base for height adjustment.
same as the front, but in seperate areas. works the same way though
Why thank you...
Mine came with Impul springs but with the Impul kit its super low and there is no way i will get through the ID check with it as it is...
Why thank you...
Any idea what the cm drop from standard the impuls provide? I have a set of s-tune springs you could borrow if necessary, they drop the car 2cm from standard I think.
Low. Top of tyre to edge of guard is about 15-20mm max.
SA reg doesn't go on tyre to guard distance though does it? It goes on lowest point to ground?
Well they have a concrete block you have to drive over when over the pit at regency but I'm sure they would pull out the ruler if need be.
As for the ID check, they don't measure at all but if it looks too low they won't pass it and you will have to come back. No fine but just the hassle.
Its going to be a hassle either way. Isn't it less hassle to just present and fix it if it gets rejected?
Who did compliance? I thought anything that didn't meet ADRs had to be removed at compliance, hence all the good stuff usually got stripped?
Parts were removed for compliance and re fitted after.
Purchased the car through Chef, compliance work done by japlink.
I will prob go down and see how I go but like to be prepared as far as being able to swap what ever I need to get it through. May just go down the road of coilovers now, was going to be an eventual mod but would have preferred getting my 19's first :)
It's really up to the workshop when it comes to aftermarket parts, if they choose to put them back then it's a win for you. I had the benefit of knowing what was on the car before shipping so parts had to be put back.
yup i would guess about 30-40mm above standard and about 60-80mm below lol
i might be exaggerating that, but there is PLENTY of adjustment, front and rear
When I enquired with Just Jap they didnt believe they could get it to above stock height - they thought they could get JUST to stock height.. but no higher. They, apparently, asked the workshop next to them who fitted the BC's to their workshop/demo car and that was what they thought also. I are teh confused.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
