the rear spring seat is threaded for spring pre-load, and the damper also has a threaded base for height adjustment.
same as the front, but in seperate areas. works the same way though
Why thank you...
Mine came with Impul springs but with the Impul kit its super low and there is no way i will get through the ID check with it as it is...
Why thank you...
Any idea what the cm drop from standard the impuls provide? I have a set of s-tune springs you could borrow if necessary, they drop the car 2cm from standard I think.
Low. Top of tyre to edge of guard is about 15-20mm max.
SA reg doesn't go on tyre to guard distance though does it? It goes on lowest point to ground?
Well they have a concrete block you have to drive over when over the pit at regency but I'm sure they would pull out the ruler if need be.
As for the ID check, they don't measure at all but if it looks too low they won't pass it and you will have to come back. No fine but just the hassle.
Its going to be a hassle either way. Isn't it less hassle to just present and fix it if it gets rejected?
Who did compliance? I thought anything that didn't meet ADRs had to be removed at compliance, hence all the good stuff usually got stripped?
Parts were removed for compliance and re fitted after.
Purchased the car through Chef, compliance work done by japlink.
I will prob go down and see how I go but like to be prepared as far as being able to swap what ever I need to get it through. May just go down the road of coilovers now, was going to be an eventual mod but would have preferred getting my 19's first :)
It's really up to the workshop when it comes to aftermarket parts, if they choose to put them back then it's a win for you. I had the benefit of knowing what was on the car before shipping so parts had to be put back.
yup i would guess about 30-40mm above standard and about 60-80mm below lol
i might be exaggerating that, but there is PLENTY of adjustment, front and rear
When I enquired with Just Jap they didnt believe they could get it to above stock height - they thought they could get JUST to stock height.. but no higher. They, apparently, asked the workshop next to them who fitted the BC's to their workshop/demo car and that was what they thought also. I are teh confused.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
