go the Fcon, as a Stand alone it will be a much better ECU if tuned right, and as you say you have the goods.
I can guarantee a few people here will be HIGHLY interested in the results of an FCON.
good work hooking that up.
  • Replies 186
Posted Images
this is guna be a projec and a half , well i got some good info time to start playn around
ill start with the ecu and go from there as any mod after can be done with tune
yeh i've also heard your going to scott for some fabrication work. good decision lol
ye i like his idea of a turbo set up good researchn on his behalf
im also after a dump pipe and front pipe with sports cat to suit a kaki n1
and for now hopfully ill get a copy of his manifold adapter to use while i look at getn a full custom manifold
S t High tech
quoted a full stand alone ecu hks f con pro and install for 4 gs
what you guys recon go for it or na go emanage piggy back
S t high tech Soichi is well know tuner for nissans used to work for nissan japan before comn to nz
he recomends the hks and recomends satnd alone when upgrading turbo
also hes like a farts distance away from me 30 sec drive
( drool appeares at corner of mouth )
I can buy an Fcon for $1800 in Japan, it will come with a plug in harness and all required sensors, is he charging you 2 grand to plug in a loom and tune it with the help of preset maps? Sounds way too expensive when you compare the results im getting with a $600 unit.
The HKS unit is still a piggyback unit but YOU cant use the software, unlike the Emanage. It has greater tuning resolution which you realistically wont notice and a few extra adjustments apparently, but wont adjust cam timing or throttle as I understand it. I agree it is probably the better unit but at 4 times the installed cost it would want to be...
I wouldn't bother with the manifold as we are restricted in turbo size anyway due to the factory placement, im pretty sure the stock manifolds will flow 350kw which is around what a GT30 will ever flow.
Check out the HKS 350z kit, they used our stock manifolds by the looks of it, meaning it wasn't worth fabricating. I could make one but engine out job means it probably isnt worth having the car off the road for another week.
sweet :worship: , ye i ordered my gtx from that atp website link that u showed me , hit the bank acc a bit :(
but i want my car to be a street :ninja:
he is talking about using the full hks stand alone ecu not the piggy back
price was for harness and install
also he is well know for tuning skylines and is very competent with the hks plus being around the corner kinda makes it all like the way to go
Edited by Sidius
and I thought I was spending lots of $$$ on my car...:whistling:
well all i know was that he said for the nm35 with the turbo that i bought and mods i want go full hks stand alone with install
gather that hell work it out
dont the stageas like getn a new ecu ?
I agree, HKS is a good option, but at that price I would feel ripped. Is he saying an Emanage Ultimate cant do 300kw? lol.
he just said he prefers hks has used it for so long and has used it on so many skylines
also being ex japan nissan tech he said he prefers using them with the nissans
http://sthitec.co.nz/
check out his diary, about us and cars hes done
Seriously dude, doesn't mean shit unless he's worked on an NM35 or VQ25DET before...
so far he's shown that he doesn't know the FCON V Pro for the VQ25DET is going to be a piggyback setup.
Not sure if that's a good start. I mean everyone's gotta start learning somewhere...you can do ECU swaps but you'd need to import them from Japan. Nismo/GZONE/Impul...
You can pick up late model fcons off this forum.. for 500ish.. buy the loom for 400ish from japan and vola!
and you better hurry.. as m35 shit for fcon is going to be discontinued...
p.s. sometimes people think fcon vpro is standalone in some cases... but in a few it isnt.. m35 is one of them as is gtr.. simple mistake..
Saw one go for $500 but that was AGES ago. They're bloody rare...same thing on firesport...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
