  • Replies 186
Posted Images
Soichi said he hasnt put it up on his page yet but he sent me a link to a tuner mate of his in wellington
http://www.speedtech...ent+System.html
and said all that you read there he can do
as in use the hks ecu as a piggy back install yet a stand alone ecu
and they have off the shelf harneses for the vq25det , he says look further down at make and model and ull see vq25det
Edited by Sidius
so why cant the nm35 run a stand alone ecu
wouldnt it be like any stand alone ecu
new ecu goes in and tuning , maping is done
all i know he said around 4g for full stand alone installed
beacuse like the gtr it has a whole lot of other shit to run off the factory ecu.
let him know its just a plug in loom with fcon and m35 and see what he says..
Haha, 2k for an install with a plug and play harness, I need to get on that gravy train... Even if it is tuned that's very expensive.
For 4k I would be putting a Motec M800 in I think.
At least you have an authorised HKS tuner around the corner, I would have to drive 1000k's
as scott said.
got the kakimoto R exhaust. i have not seen an exhaust where you can see straight through the 80mm of goodness(pipe) lol
for an exhaust shipped for $1000 i think its the best ive seen. cant guarantee it being quiet though :P
flames will definitely be happening. *looks at craig*
as scott said.
lol lets have a loudness competition when mines done :P
lol your using a flappy thing though arent you? or changed your mind? i have a feeling mines going to be louder than before, its seriously a straight through pipe. im amazed its beautiful lol.
^^lol show off
well heres some better and more accurate pics of the kakimoto system.
this is what came with it,
this is the mid pipe hotdog styled mufffler - straight through
and the tail pipe muffler - straight through.
can't wait to get this exhaust on.
^^lol show off
scotty got any pics of ur front pipes, race cat and downpipe , my kaki n1 full mega is on its way
I don't even have the turbo yet buddy... Give me two weeks, unless you mean the old system? I fit it into Sage's car last night.
f**k i still want this 3.5 inch u ass.
Sidius, you wanna buy my dump off me? lol
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
