I had a quick look, I cant see if anyone suggested two different engine mounts???? Perhaps an rb20 mount or rb25 one on one side and standard on otherside???
Does that class as outside the box???
  • Replies 277
Posted Images
Its not my place to say it here so I won't.
Adding spacers to the rear of the bonnet works though :P
Just do the marko and cut that bracing!
It's still using standard RB26 mounts :(
If you want it to fit, take your car to Mick at Signature Performance in Raceview QLD :P
I know that Paul probably knows' how to do it, he has been talking to Mick ;)
Fitted my Sil80 road rims/tyres to pass rego as the tyres on the Enkie's have bald inners due to shit alignment crap castor.
Here's a few pics
Just fkn tell us already!!
Mine "fit" without changing anything but the bonnet just barely closed, and that was with spacers.
Now I have slotted the engine mounts and gained some more clearance (2WD platform) but I still want to know wtf you did! Please don't let this question drag on for another 6 months!!
I was going to suggest that the timing covers are 'off' early this morning....but I didnt have anything to compare too.
Just checked out the pictures again. Drivers side high point been ground down...
lol just looked again and now im not so sure :cheers:
Edited by r33_racer
  • 3 weeks later...
Marko thanks for putting us out of our misery. Unbelievably (because I wouldn't expect anyone to believe it now) when I did mine I fleetingly wondered about RB25 covers, knowing that they are slimmer. Didn't think it was enough to make a difference though. And I was a bit dogged about keeping the RB26 ones. Bugger!
ive had an abundance of pm's on this thread so here is the answer...the engine covers are not rb26 BUT rb25 (or was it rb20) :unsure:
errrr.. but in the photos he still has a RB26 cambelt cover on.. and this is one of the main parts that interferes with the bonnet - my engine covers don't hit at all - only the twin turbo badge and the RB26 Cam-belt cover.. How does changing the engine covers help Marko? Am I missing something obvious?
Really appreciate that someone has actually told us something though - rather than just dicking us all around.. after all this isn't a secret internal engine mod for more ponies or some tuning secret - its just how to get these thing to fit without cutting the bonnet and another step toward making the car 'legal'.. just what forums are for I would have thought.
Any more info other than engine covers Marko?
I understand your view but if u reduce the height via cam covers then marry the rb26 front cover to suit the new height the clearance is accomplished...or just use the rb25 front cover as well
Anyway, once this mod is done it doesn't address the clearance issue with the twin turbo pipe as it will rub the paint off if resprayed like mine?
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
