hey all well we just finished a rb26 conversion in the ceffy and when it came time to put the car on the dyno the car would not disengage with the pedal all the way to the floor.
the clutch is bled fine, we are running a rb25 gearbox and a direct clutch services solid centre twin plate clutch + flywheel with the standard rb25 thrust bearing(new of course) + fork pivot(not spaced).
now we wound the adjustment at the clutch pedal to its maximum and this fixed the problem but the clutch pedal HAS to be touching the floor hard to disengage the clutch and over time obviously when the clutch wears slightly the same problem will occur so what can we do. also i am not going to risk things in regards to hard gear changes while the car is like this want it fixed before i start giving it a load.
to fix this problem i'm thinking maybe a spacer and upgraded fork pivot ??? or i have read about the use of different thrust bearings and carriers being used with all the jap brand clutches has anyone had experience with these particular clutches ???
also im thinking whilst this is going on mabey a braided line and by passing the jointing block would help things slightly ???
any help would be great
Hate to say it but I'd say its a gearbox out job. If the car still wants to "drive" with the pedal pushed in the clearances arent right. Was it a custom clutch? what pressure plate was used?
A mate of mine had some super duper custom twin plate for his XR6T and it took us forever to get it right. It took 3 different places to setup the clutch before the clearances were correct. Thats why i just go the jap stuff now :P
I haven't used this particular clutch but my exedy hyper twin i bought gives you the recommended sleeve length on the bearing carrier. The recommended length is 14-16mm, i don't know if that will be the case with your clutch. Here are all the nissan part numbers for different sleeve length bearing carriers. Hope that helps.
30501-A3800 12mm, 30501-N1601 14mm, 30501-U0200 16mm, 30501-S0200 18mm, 30501-B6000 20mm, 30501-S0160 22mm, 30501-K0404 24mm, 30501-K0510 26mm, 30501-N1600 28mm, 30501-N8400 30mm
no your money is mine i spoke too direct clutch and they designed the clutch to be used with the standard gear he said the only times they have run into trouble the solution is to re sleave the slave 1 size smaller to get more stroke
if they say OEM everything works and you've 100% checked everything between your foot and the slave (easiest and cheapest to do), and you installed a brand new clutch kit correctly (can't really go wrong much if you've got the box in and car running), then there's not much else it can be: fork/pivot/carrier/bearing :(
same thing happened to my gtr, bled it up and the clutch pedal was hard, and it would still be in gear when the pedal was pressed.. :P
had it towed to all brake and clutch and they removed and re-fitted the gear box and fixed the problem, $780 including the tow.. :P
turned out that my mate who had "worked in a gearbox workshop before", installed the twin plates wrong, they were facing each other instead of the oppposing each other.... :)
who installed ur clutch, because if u don't do it ur'self you never know??? :D
that's my 2 cents
I'd also be checking you haven't snapped the mounting brackets off the firewall for the clutch pedal...
I snapped the top one off with my setup, and could only JUST get the thing to disengage.
  • 1 year later...
Strange im having the same issues with the same clutch hmmmmm..... so bearing carrier lengthened will fix this hmm DSC told me bearing would be fine standard...which it isnt apparently
tried
replacing nismo slave with standard slave
replace braided line with solid
replace clutch master with another that worked in our track car.
spaced pivot ball out
removed dust plate from engine/box to get it closer.
was looking at cut and shutting the pivot ball to make it longer (got it spaced out 10mm atm to compensate for the 10mm thick adaptor plate (gearbox/engine)
bearing carrier will be a better idea by the sounds of it making it sit closer than the standard one im using atm...
OP what was your resolution to this problem??
Edited by xris
  • 3 months later...
As above ive got the same clutch and had the same problem with it as the OP. Now ive had my slave resleaved and it worked. BUT...it was super heavy and still at the bottom (about 15mm off the floor). short story engines bearings died and its apart again.
Now.....if i change the bearing carrier over. to a thicker unit will this increase the height of the release point? im looking at trying to make this more user friendly (hopefully i can change the bearing over and swap slaves back to normal and have not so much a 10kg spring to push.
will that fix my issue? and what is the standard sized bearing 12mm?
  • 2 months later...
Sorry for the resurrection but it hasn't been dead for that long.. :P
Anyone know where I can source one of these smaller diameter release bearings/carriers? or have a part number?
Cheers!
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
