  • Replies 103
^You just have to complete the international B license to get it.
K heres my time, 1:43.020. Had a minor off or else would definitely have been in the 1:42s.
Sports medium - everything stock, no oil change, no tcs no aids.
Edited by Ten Four
fuji 2005 GT
DC5R - 268HP
Mods: Race exh, rom chip, stage 1 na tune, R3 tyres, race suspension, triple plate clutch, race flywheel NO OTHER MODS
1'50.739 first try
would be willing to go that car round NUR if whoever else said they wanted to do FWD has one to similar spec, dont want to mod this car any further tho
i got a 144.033 on a pretty sloppy lap. my very first lap was a 1:49. i only did about 6 laps as i then had to go cook tea. will play it again tomoro night or on the weekend (gotta drive down the coast after work today so no playing it tonight).
fuji 2005 GT
DC5R - 268HP
1'50.739 first try
will give that a go on the weekend. don't like the nur as i really suck at it
tenfour, can you confirm what mods you are running? your car is SIGNIFICANTLY faster than mine, your gearing is different and you have an epic amount more grip.
I think from here on in we need to set some rules if we are going to have some competitive fun.
Here are my recommendations for rules:
R3 tyres or less
No weight reduction
No increased stiffness
No race brakes
No brake balance controllers
No gearbox
No carbon prop shaft
No added downforce
No yaw or ACD controllers
Unlimited HP mods but MUST state exact HP and mods
No suspension kit limit
No clutch, flywheel, LSD limit
Traction/under/over set to zero
Basically want to keep things as realistic as possible. If you guys agree we can have some fun.
Mate. I bought a new DC5 from the honda place. Did the mods you listed except the suspension, cause I forgot. I also bought some 2nd hand rims, but I don't think they affect anything other than visual??
R3 I assume you mean racing medium, which I used.
Checked again:
Race Exhaust
Na Tune Stage 1
Performance Chip
R3 Tyres (medium race)
Tripple Plate Clutch
Race Flywheel
That is the only mods I added. As said, forgot suspension.
Oh, also mine says 264hp in garage.
Happy to take on any challenges, I just play it too much.
Edited by Ten Four
lol u mean a bmw? what model and what mods, ill see what i can do, ill need to get money probably coz i dont do up alot of euro.
edit:
ok heres what ive got:
M3 CSL - stage 1 na tune, semi race suspension, twin plate clutch, semi race flywheel, stage 2 weight reduction, race brakes
breaks the rules, but if u want to build one to same spec we can use those on el cap, it goes around it well
lol up to you, i just ran a 1'42.389 with the csl and above mentioned mods
if you want to set the challenge, specify track and rules and ill stick by em
tracks like el cap with uneven surfaces really do it for me :D
Here we go... 1:48:798
Oh shit, didn't use race suspension lol. Oh well stockie suspension was on this time :D
I did a 1.48.649 with the race suspension.
Also was playing with the nike. Got a 1.41.5. Will post a pic on Monday
Will go and play on the new track now
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
