I've got a mate with an R33 GTS-T Series 2. He knows the previous owner who has imported it and looked after it well. It's straight and very tidy looking. The only mods it has is a pod filter, FMIC and 3" turbo-back exhaust.
It used to misfire badly but that problem has been resolved with new spark plugs and Spitfire coil packs. Series 2's have ignitors built in to each coil pack so the ignitors have effectifely been replaced as well.
I have cleaned every single connector on the car with contact cleaner, rubbed the paint back behind all the major earths for a better connection, cleaned AFM, checked all wiring for damage, cleaned piping, blocked hole in BOV, all the usual stuff to help get it running sweet. The previous owner has replaced the fuel pump with a brand new nissan one.
You can be driving along and the ignition and fuel would just CUT. Can be for long enough to stop and can be in the form of a brief cut then away you go. It doesn't pop or anything when it cuts back in which leads me to believe it is spark and fuel. Not 100% on the fuel bit but ignition is DEFINATELY cut. All the dash lights that are usually on when the car is running remain on. It's not like a pop or bang, just like if u turned the key off while driving.
The previous owner has taken it to a few of their trusted places time and time again without success.
Any help or similar experiences would be greatly appreciated.
https://www.sau.com.au/forums/topic/268661-r33-gts25t-s2-randomly-shuts-off/
definately sounds like an electrical fault. hav u checked the ecu for error codes?? sounds like something is shorting out, like a wire is exposed and earths out every now n then. my bro had thermo fans on his n the relay stuffed up and his car just wouldnt run coz if the ecu is shorted it causes the car to shut off. definately a head f*#k, good luck with it.
No error codes. Have borrowed my mate's laptop with Nissan Datascan and consult cable but I can never catch it doing it with the laptop plugged in and I can't borrow the laptop for more than a few hours.
I'm lookin at the PCB in the AFM now and the solder joints look a little dry but not cracked off. My mate has already purchased another S2 AFM that looks grottier on the outside but u never know!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
