I cleaned the filter in the tank when I put my Walbro in but since I'm getting a tune tomorrow i thought I'd change the main fuel filter (just in front of and below the brake master cylinder). Its a bit of a pain to get at (like the plugs!) which may be why they are often overlooked. It helps to remove the bracket as my hoses were somewhat frozen on the filter. I cut it open with a hacksaw and it was chock full of gunk! I have also been using a 10% etheanol fuel (Gull Force 10) in my new car and apparently that helps to clean out the tank but all the garbage deposits in the filter. The filter is just a generic item (I got a Ryco Z200) so you don't have to buy from Nissan.
Worst case scenario a blocked filter can starve your engine of fuel and cause it to self destruct so if you can't remember when you last changed your fuel filter do it this weekend!!
https://www.sau.com.au/forums/topic/268668-fuel-filter/
putting that on the list of stuff to do this weekend !
Speaking of spark plugs, i am going to remove mine to check condition and mainly gap settings. I could of sworn i read somewhere that as soon as you up the boost to around 10-12psi, you need to gap the plugs to .8mm instead of 1.1mm. I am noticing the power dip higher in the revs, and I am pretty sure this had something to do with it. sorry for going off topic !
https://www.sau.com.au/forums/topic/268668-fuel-filter/#findComment-4577545
Should always gap RB plugs too 0.8mm.
Dying off up top? what is the exhaust setup?
https://www.sau.com.au/forums/topic/268668-fuel-filter/#findComment-4577774
gap size depends on how good your electrical system is.
Im running 1.1mm with 15psi+ and no misfiring. Although I have splitfires and new battery..
interesting.. mine was fine at 1.1 with a 600cca battery, 7ish psi, and stock coils haha
https://www.sau.com.au/forums/topic/268668-fuel-filter/#findComment-4578306
Did a full oil change today. Put in the oil filter relocation kit, and, bugger, it is right over the fuel filter. Did not think about that did I?? Anyway, my filter cant be too blocked caus last weeks series of mountain climbing used 20/100. It was fun.
I might have to get a fuel filter relocation kit. LOL
Incidently what has a 600cca battery got to do with sparking except during cranking??
Edited by 66yostagea
https://www.sau.com.au/forums/topic/268668-fuel-filter/#findComment-4578394
nice
should grab one myself, to go with the oil filter - same spot for mine with the oil filter relocation
been busy doing my turbo up, but Im seized up in the back now
sux
called a local mobile mechanic to come out tomorrow for an hour to finish it off
- do up oil line
- do up 2manifold bots +2 catconverter bolts
- do up the intake / afm / vacuum lines, etc
and while he's there for that hour do the oil filter (I cant get it off) and fuel line, although I regularly have them changed when with the dynomen
but yeah, disappointed Ive had to call someone in to help me finish the job, so hard being so tall with no knees, asmy hips and back are all rooted now
sigh* :D
https://www.sau.com.au/forums/topic/268668-fuel-filter/#findComment-4579595
Too much carpet burn my friend.LOL
Where I put my filter relocation kit is right above the fuel filter, so next oil change i will replace and relocate the fuel filter.
Oh, the joys of modern motoring.
https://www.sau.com.au/forums/topic/268668-fuel-filter/#findComment-4579712
did a service on the wagon today and also did the fuel filter. i can confirm that the Ryco Z200 fits a S2 stagea. i have 76000 on the clock and the filter that was in there was a genuine nissan one so i'm not sure if it has ever been changed. anyway after i pulled it out an tipped the fuel out of the filter all this black crap come out. as Kiwi has said, its definately something that needs to be changed if you haven't already done so.
https://www.sau.com.au/forums/topic/268668-fuel-filter/#findComment-4596677
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
