Hey Guys
After following a few of the r34s getting tuned of lately i decided to take the plunge and get my car tuned aswell. So after a few phone calls to CRD i organised the truck and shipped it down to Sydney. The car being a stock standard Vspec11 Nur with a Nismo exhaust i decided to add a few bolt on goodies of them being Sard 700cc inj with a Sard fuel reg, HKS fuel rail, Bosh 044 intank pump ARC airfilter box, Tomei poncams 260's, Apexi power fc and a ATS clutch to handle the increased power. Well what can i say Jim from CRD called to let me know how he went with it and i thought he was having me on exceeded all my expectations shipped the car back home and gave it a test drive and all i have to say is F*** this thing drives so much smother comes on boost earlier than before even off boost it is heaps more responsive than ever before. Oh i would just like to add this was tuned on 98 fuel and the turbos are the standard n1 turbos that come with the Nurs. So on this note i would just like to thank CRD you guys seem to be on a higher level when it comes to tuning and modding GTR's :D
https://www.sau.com.au/forums/topic/268844-gtr-34-vspec11-nur/
Um is the second graph showing PSI?
As in your running 25 pound tapering off to 21 through standard 34 N1 turbos...
Do you have a before graph?
Should be one hellova ride though!
Yes i dont know why the boost tappers off it will hold 22psi it might be the standard wastegates on the turbos or the two cats the exhaust runs but yes it is a fantastic ride.
I expect it declines because N1s stop producing power at the top end over 1.3bar or so,
your car is going to 1.75bar at boost onset, then declining down to the best the N1s can manage.
Is there a boost controller in the mix as well?
Yes there is a HKS boost controller.
where are your torque figures?
On the first dyno pic up the side just under 9000
it feels very torquey when im driving it.
Wow - i thought N1s/-7s/GT-SS were out of puff at about 330kw...
Please put this in the RB26 turbo sticky.
+/- 20kw really, also consider its running a few extra PSI than what most people run (20psi) so all things relative its pretty much spot on :starwars:
ahhh, the beauty of stronger internals in the Nur motor. Congrats Nick.
Stronger internals yes maybe how much stronger!! well that can be argued all day long. Was it the increased strength that gave the power figure above in this instance no i don't believe this was the case either this one was done purely on tuning ability. This thread was not put up to compare anyones car this was put up by me only to share my happiness at my result. There's plenty of other guys on this forum with the same set up running roughly the same amount of power no records broken here just a great setup that has made this car so much more fun to drive. By they way thank you for editing your post if you would like to talk to me about getting more power out of yours pm me id be more than happy to tell you how.
Is there 2 different cars plotted on these graphs?
I see the NUR is making around 320awkws and the R34 GTR is making 358awkws.
So assuming your car is the red line who's is the blue line?
And what happened to the rest of the graph? Speed or RPM would have been nice to see...
i was just about to post that.
  • 4 weeks later...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
