  • Replies 79
So you are entering in the dyno comp then paul..... Hmmm maybe i might have to enter ole Sly then aswell ...well if you guys are rockin up to move your cars past all the other bloody show cars AND THEN onto the dyno pack dyno i will prob see you on the dyno hmmmm say about 2pm, mine will prob be on there then at 4. That dyno is really accurate and all but honestly why would it be allowed in show use with 40 cars in line, to swap a s15 silvia to a 180 sx today timed a bit more than 25 mins, dunno whether or not they where takin it easy but the crowd didn't like it and half went away. I have no doubt these dyno packs are awesome for reading but as i have now seen are quite time consuming, plus possibilities of wheels getting damaged and not too mentioned not being put on tight enough.... if you had changed 200 or so wheels in one day i know i couldn't be stuffed tightening them all up properly *mental note to you all, never let me tighten your wheels*:( :bahaha:
Good showing everybody.
Was nice to put a few more faces to names (or nicknames). Congrats Paul on not blowing up your engine and bettering your dyno with a 431HP. Sensational. Shirts are good too. Quite a few Skylines which is great, couple of lovely GTRs....mmm...
Originally posted by 25GTT
That dyno is really accurate and all but honestly why would it be allowed in show use with 40 cars in line, to swap a s15 silvia to a 180 sx today timed a bit more than 25 mins, dunno whether or not they where takin it easy but the crowd didn't like it and half went away. I have no doubt these dyno packs are awesome for reading but as i have now seen are quite time consuming, plus possibilities of wheels getting damaged and not too mentioned not being put on tight enough.... if you had changed 200 or so wheels in one day i know i couldn't be stuffed tightening them all up properly *mental note to you all, never let me tighten your wheels*:P :bahaha:
For starters we use torque wrenches on all wheel nuts, every single nut across the 34 cars we dyno'ed over 2 days have their nuts done up to the same safe level. We are extremely mindful of such concerns about wheel damage etc.. Why do you think we dont use rattle guns? We've got em, dont use em on street cars.
Secondly your time concerns, yes there were a few cars that took longer than others, the 4wds obviously. As far as whether the crowd liked it or not, we didnt give a shit. We were doing our job as quickly and reliably as possible, or do you want us to drop wheels on their face on bitumen? A GTR today had to be taken off the dyno after being completely bolted up due to its body kit being too wide and the risk of damage to the car was considered too high.
But i guess you think we should have run it anyway, cracked the sideskirt off, just to please the crowd, so we didnt waste any of their precious minutes.
Red17
Red17
Points taken red 17, in no way did i say that you guys did a bad job at all, in my post i also said the dyno has been praised as being quite an accurate dyno, however we must keep in mind that th show wouldn't be the show without the crowd. you guys did do a fantastic job and i have no doubt that you guys have excelled more than what most people have done or what i could do, changing those wheels would be annoying and for you guys to stick with it all day was well done.
My point however is that although the dyno is accurate the problems with it is time consumption and now as shown the problem with putting cars on with wider body kits, of course i would rather the GTR not go on there but this is an advantage that a normal dyno would have had. It's unfortunate that we can't say stuff the crowd as half of the SAU guys on here are "the crowd" we have to give a shit about them as they are the ones that have paid $15 entry to look at cars and without the crowd the show is not a show.
Anyways - you did a good job dude and now that you mention it I am bloody glad no rattle guns were used especially with what happened to one of my old mags a few years back!
I think Ivan and the APA guys did a great job, yes it does take a long time, but they worked there asses off, and if people weren't so precious about having the cars shown on Sunday arvo then they would have done even more cars.
Even the DD dyno's won't necessarily be able to handle really slammed cars:(
BTW, special thanks to Ivan for not blowing up my car:D
Thanks for the praise fellaz, i should apologise for my tone in my original post. Id just gotten in from PAS and the APA team had been severely chastised by a certain person on a certain trade stand for quote "running a dyno comp nobody ****ing wants".
So suffice to say I was not in a good mood.
Red17
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
