Mine is a custom enclosure, technically, it sits where the spare tyre used to sit...
I've never had one above the fuel pump but that seems to cause alot of people problems. You'll probably find as well now that your RCA cables have been penetrated by the power and are creating noise, they will not shield as much anymore. Weird how it works like that but I've seen it happen a few times...
Can you ground your RCAs in any way? Normally the good ones have an extra cable running with them that you can ground to help minimise noise.
Here is a pic of my setup, completely useless to you, just thought I would share :DClicky!
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582770
i been trying diff grounds for amp no luck , bit better but noise does not go completely.
gets higher when i switch my lights on :D
i also tried relocating leads , only other way i can thing is if i run them thru middle of the car ...take passenger seat out and run rca's throught .
i cant ground my rca's , doof that setup is nice ;)
thanx for quick reply's boys
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582785
Crossovers will be fine. Do you have a spare set of RCAs? Even ones that aren't shielded?
Like I said, once the RCAs are corrupted, without getting new ones, you're going to have a tough time getting rid of the noise completely, but you have to sort it out or the same thing will just keep on happening.
What spec is the amp? And what grounds have you been trying? I would keep trying to find a good ground if I were you, maybe sand back some paint if it's stopping a good connection.
What about your battery? What's that like?
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582822
i got a new set of rca yesterday , amp is mtx maybe 6-7mnth old(about 60x4 rms)
i took the spare tyre out and there's few points where i sanded paint off and put ground there.
battery is standard.
did you run your rca and speaker cables together or yours are separate?
damn corrupt rca's hehe
i might try taking h/u out and checking if any of looms cables are cousing it but i doubt that.
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582838
I'm trying to remember how I did mine...
I ran a lot of wires up the middle but I forget which ones :D basically, I kept all RCA and any power wires very seperate (i think)... I've never had a problem.
My system is set up just a WEEEEE bit different to yours though... not a very good base for comparison at all.
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582864
i took the head unit out fiddled around a bit lowered noise tiny bit but once i turn my headlights on noise is back.
im getting sick of it , i think i will take the amp out and run the system off deck , i only run rears and fronts
the whine is killing me hehe
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582927
I've run RCA's next to speaker power wires, they are twisted pair RCA's though and I don't have an issue.
Not sure if it was the twisted pair construction which helped or not, I'd like to hear an opinion on that. The guys on Mobile Electronics seem to recommend twisted pair RCA's to prevent interference...
I also had what looked like car power wires running up the LHS and RHS of the car (battery in boot) I tried to keep away from them but the RCA's are pretty close, no issues though...
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582957
heres a few things to have a look at.
re-earth your car not just the amp.
That crappy earth wire that runs from the passenger inner guard to the exhaust manifold on a r33 needs to be replaced with something that is thicker and can handle more current difference.
Your head unit, a nice thick piece of graound cable from the chasis of the car to the chasis of the head unit.
Your power wire from the amp to the battery, move it away from the fuses and main feed for the car.
your earth wire on your amp - connect it to a different bolt in the boot than the factory earthing bolt under the battery.
make sure all the connectors you use are soldered, dont just rely on those crappy "gold" screw type connectors.
RCA's - twisted pair is a marketting ploy to get more $$ outta you. The amount of money you would need to spend on a system to hear an actual difference in RCA performance is more than you would spend buying a r33.
you can just always earth the outer sheilding on your existing rca's aswell..
if you do these basic's it should be fine as long you have good quality equipment.
My amp sits on a piece of timber mounted above a hi-flow intank fuel pump and the system has no noise to it.
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4582988
to grond the rca's
you need to
- be careful
- cut through the plastic sheilding of the rca cable til you get the braided cable..(this goes to the outer part of the rca plug.. and it may also be a wire rather than braid on cheap rca...
- do not break this braid/wire - join another wire onto it
- becareful when soldering as to not burn through your rca's totally
- do near both ends of the rca cable
- once you have a wire soldered in at each in - earth each wire directly to the chasis
- do not earth them to other wires or amp/head unit earths.
thats about it, take your time and dont rush..
https://www.sau.com.au/forums/topic/269049-rca-noise/#findComment-4583095
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
