Hi Guys,
I know there is a BIG 'what is E manage' tread in this forum.
There is alot of helpful information in that thread, but I want to know if anyone here has one hooked up to a Skyline??
And what was the result and your experience??
Any issues with the firmware, software etc??
I know there is a newer version of the firmware (v1.36), but don't know exactly what is the difference from the old version.
Just want to know who has one running in their car and how it has perform.
Cheers
:P
https://www.sau.com.au/forums/topic/26918-e-manage-with-skyline/
  • Replies 44
I have a cousin who had just done that. Full E-manage suite. He's running .8 bar with a profec e01 which is part of the e-manage suite. Together with this he has the following mods:
trust fmic
hks dump pipe
hks 3" front pipe
high flow cat
3.5" hks hiper cat back
k&n panel filter (stock airbox)
tein ha adj coilovers
18" (235 at front, 265 at rear)
the car's gained an extra 30.5 kw at the wheels.
Any further details contact Peter from Advan at Silverwater.
Strutto, has anyone actually proved that the manual PFC is no good in an auto? I am running a modified manual ECU in my auto and am able to increase the boost to 1bar, although it wont hold until i fit an electronic boost controller. It also changes hard between gears and generally goes better with no real difference in fuel consumption. I have had no adverse effects except for occasional stalling but that was the case with the standard ECU.
Read this thread
Craz0 has tried it... Didn't work for him :(
4door_sleeper has it working :looney:
I haven't tried it... But if someone wants to lend me one I'll give it a go... :(
My theory is that the original Nissan ECUs "relay" information to the auto ecu whereas the powerfc's do not...
See that is why I went for piggy back instead of the PFC, car is auto. It is still not 100% certain that the PFC work with the auto ecu.
Craz0 mention it has worked but there is still some errors or bugs. Like the flashing of the power/snow switch.
Guys in the states has used an E-manage with a R34 (auto) and it was a success. More info can be found at the yahoo group - emanage. They got heaps of info there about the e-manage but not much on e-manage with skylines.
666DAN, you say the PFC can't be used in an auto can you tell me why?I just explained, I am running a Manual ECU in my auto and am having no problems, the auto has its own computer, the two talk to each other to limit the revs between gears and won"t allow any increase in boost over factory. Im sure that there is more to it than that, but no one i have talked to about it in a 12 month period has had anything more to say than put a 5 speed in it or you can't do it. ... There is no real difference between PFC and a standard manual ECU except the obvious ability to customise settings. Mind you my experience extends to 33's not 34's.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
