You should be able to do this your self.
Maguire’s all metal polish works well and they come up like new again.
Just be aware they will need to be done regularly as it removes the protective film, but it's definately worth doing.
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4585917
on my old Gt-t the the build up was actually on the inside of the headlights, I was the first owner is aus and when I bought it it didn't have that
My guess was it had something to do with when the compliancer took out the factory xenons it ruined the seals and let the haze gradually build up over time.
Was going to open up my headlights using the DIY on here somewhere then clean the inside but I sold the car anyway
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4585930
The only way you'd stop it coming back is to have some sort of protective film re applied professionly.
Don't know if this is possible or not.
why bother.... $20 for the bottle that will last you at least 20 cars life spans and 2 mins of your time every 6 months is fine...... recon that would be cheaper and just as effective....... plus you get the feeling of making something ugly become beautiful again lol
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4586280
anyone know if you can get glass covers for the 33/34's instead of the plastic jap specs? mine look clear untill i turn the lights on. i've heard you can spray clear coat on them and it stops them from oxidizing, makes sense but haven't seen it done to confirm it.
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4586305
Maguire's all metal polish works well and they come up like new again.
Metal polish????? should use plastX instead then lol....
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4587939
When I polished my headlights I started with some 1200 grit wet and dry abrasive paper, moved onto 2000 grit then finished with Maguire's StratchX. Probably spent a good 45 mins per headlight, but 18 months later they only show a slight yellow tinge :D
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4588342
Couldn't agree more, any fine cut abrasive will do a good job, including toothpaste, autosol metal polish is what I use cos I found some in my shed.
It's quicker to start with 2000 grit wet/dry paper, soaked in water for half an hour, then rubbed over avoiding the surrounding paintwork. When it looks like shite, hit it with the finest cut polish you can and plenty of elbow grease and marvel at the results! I've done mine 3 times in 5 or so years of ownership.
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4597438
  • 1 month later...
http://www.gtglass.com.au/HeadlightRepairs.htm
I booked in with these guys for tomorrow, will let you know how it goes!! $70 a headlight sounds a bit pricey I know, but mines coming from both outside and inside, and I'm getting desperate
(P.S. I have done the sand down + polish technique a couple of times since last year and it keeps coming back (maybe it is due to the fact it lives outside)
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4685152
$140 is cheap considering the whole front bar has to come off to take the headlights out of the car and also taking the lense off is a major pain in the ass (needs to be over baked or use a heatgun)...but NOT CHEAP at all if he's only gonna sand/machine polish the outside of the lens (which is the most likely scenario). Let us know how it goes .. these guys have franchisees everywhere it seems
Edited by Delta Force
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4685584
Hey guys,
This was done yesterday and overall I'm pretty pleased with the result. The outside of the headlights are almost perfect (the surface is now smoother than the finish on my car) although the inside wasn't done which mean there are some very feint cracks even more visable now that the outside is crystal clear.
With the headlights on at night there isn't any more cloudy dirty appearance from the plastic so I won't bother getting them opened up anymore.
Photo's attached but I don't have any before shots :sick:
https://www.sau.com.au/forums/topic/269352-r34-headlights/#findComment-4688922
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
