How many RWKW will Nismo 555cc injectors make safely?
47 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi Fellas,
I currently have 312 rwkw and the injector duty cycle is at 81% (using nismo 555 cc injectors), without a FPR
My aim is to get my power up to 360-370 rwkw. Using basic extrapolation ((0.81 x 365))/312)=94.7%), I get an injector duty cycle of around 94.7%.
However, if I install a Fuel Pressure Regulator (FPR), I will be able to increase the pressure, thus, making the injectors flow a bit more.
Anyway, I need you opinion on what power you think the injector's would max out using a FPR with my 555cc injectors.
My tuner is very confident they will make 360-370rwkw safely, as he has done it before.
Please place your vote!
Cheers
You dont need to bump something 45mins after you last posted in it dude...
Just be patient.
Your vote would be greatly appreciated!
Weren't you runing like 365 watts in your R31? What size injectors were you using?
I already have voted.
I used 740's - i knew the power i wanted, so i purchased injectors to suit it. :happy:
Im not a fan of FPR's if you've gotta buy injectors, you might as well buy the correct ones as i see it and use one of the better Nissan OEM parts.
For what you need, it'll be fine however to add in a FPR, bump a few PSI and make what you need.
without bumping fuel pressure your 555cc's would probably max out at around 330-340rwk
So generally speaking, how much more power does a FPR provide?
Also, are there any disadvantages to having a fuel pressure rgulator over bigger injectors? (Does it increase the chance of damage to the fuel pump? Or increase the risk of split hoses? Can a FPR damage injectors?)
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
