HKS 2530GT Ball Bearing Turbo, only 8,000km use.
Direct fit onto any RB20 or RB25. Comes with all fittings and oil lines and nice big hi flow HKS turbo elbow. 2530GT's are proven to provide 230-240kw at the rear wheels on a RB25.
$1950 or near offer
https://www.sau.com.au/forums/topic/26956-2530gt-turbo-direct-fit-on-rb25-rb20/
rs73--->
Never too late. I have these turbos coming in from Japan all the time ( I own and run Japanese Import Parts) if you want a HKS GT2530 or even better, a HKS GT2835R, email me now.
[email protected]
Originally posted by MRK25T
I bought a HKS3530 3 days ago from a guy on these forums. Got it hooked up yesturday.
Its bloody amazing compared to my high flow, and I havent even got the powerfc tuned for the turbo yet. I recommend it highly
You mean 2530 right Mark? If so? Thats what I like to hear.
I'm saving franticlly to get one of these.
Can I ask how much you payed or PM me?
Cheers
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
