Hey just put a new 6 boost manifold on my rb20 an did have a cheap chinesse manifold on it an the car sounded deep an tuff as but now with the new manifold it sounds a bit like a hyundai note which is pissing me off.Only other thing ive done is mount the wastegate down near the bell housing.Im goin to hav to put another muffler on it to take out the ricey sound,anyone had similar issues? thanks running a gt35r an 45mm progate if that helps..
https://www.sau.com.au/forums/topic/270043-new-6-boost-manifold/
Never mind the sound, what's the difference like on the road?
As for the sound you dont want to sound ricey, just took car for a spin then boost doesnt seem to come on earlier but it does a little more voilently,pulls real strong.It has made 402rwhp so ill put it bak on the dyno an see if there is any difference with the 6 boost.
Edited by blow thru
Have you spoken to Kyle about it?
Maybe you had an exhaust leak before so it sounded 'tough as' but now it's actually working properly it sounds 'normal'??
exactly what i was thinking
soon as i saw "chinese" manifold and a "deep note" i thought - crack/leak somewhere
Sorry dude but I just have to point out the irony here...Isn't making a modification just to acheive a cosmetic outcome, 'rice' in itself...
Hahahah
True, though i dont think thats entirely what hes doin.
I think what hes saying is that hes pissed that a expensive manifold sounds worse than the original cheaper one.
6boost manifolds that I have heard result in a more tuned pitchy note, sounds awesome. If you don't like it - give it to me :P
Mine certainly did, went from an Internally gated GT3540 on standard manifold to 50mm externally gated 6boost setup and the sound difference is amazing.
Screams rather like some of the old group A cars do.
Funny i had the same thing happen to me.
Cheap china manifold= tough RB sound.
Then put on a 6BOOST item and things quiet down a bit, i put this to the smoother runners and design of the 6BOOST manifold.
Then i put on a HKS 3.75inch exhaust, now it sounds tough again :P
http://www.youtube.com/watch?v=_PK__72sRIE...player_embedded
Definately not knocking Kyles manifold mate i tell ya well you guys no this is a work off art.I havnt had a chance to really go over the exhaust an check for any leaks but this can only be the cause,its hard to notice it at idle its only when at cruise under exceleration which leads to an exhaust leak somewhere.ill suss this out first thing in the morning.
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
