  • Replies 218
Fatz / Rob260,
When do we need to pay the final amounts? Do we pay these to UAS or through you Fatz (more cas money for ya :) )
Hi mate, not 100% sure how fatz is doing things BUT the way I run it on aus300 is money due when the parts are ready to send. The balances (plus shipping where applicable) get paid direct to UAS.
You will have to clear that up with Fatz though if you are part of his group buy.
When are the second group buy orders commencing roughly.
Won't start taking orders on these until the first batch is out the door. It's great that so many of you guys are keen but I think taking orders for a second round with the first still overdue would be asking for trouble.
So what's the holdup? As I mentioned before the cotter pin is tapered, so you have to drill the tapered hole before you make the pin. At the moment the guys are waiting for the tooling to turn up so that they can drill and make the pins. The remaining labour is minimal, as in less than a day to finish the set. As soon as the tool turns up we are all good to assemble.
So how far off are we now?
Got another set up for grabs from round 1. Guy has no job and money is tight... $197.50 to whoever gets in first.
Re timeframe there is minimal work left, just a case of when the tooling turns up.
Hi mate just after those camber arms...
so 197.50?
i read there were two versions somewhere, track and street, is this the case and if so which one is this set?
so does 197.5 cover the whole lot?
PM ASAP
Fatz: PM sent last week.. still after these, paid deposit 6+ months ago, want to know how I make final payment and receive the arms.. Talk to me bitch.
well i tell you what
johnny just called and he is picking the suckers up as i type
he has requested teh last payment and shipping and he will have them shipped within the week
the list of people who have paid a deposit are:
zurlox
lotus folding
ezzo
salad
pedator
adam macbeth
chris hall?
razor 32
john camber
my gtr32
yea baby were on!
two option
call me
0448468884
you can pay me
or the prefered option is call unique autosports 96209000 and they will tell you the shipping and give you bank details
pete
Pete, I'm going to get these sent to my work. If they're being posted I can only use a PO box. If couriered then only the physical address. Which shall I quote? Also, can you confirm the total asking price and the deposit amounts? I won't go into why I don't know, I just don't......Finally please can you confirm I'm getting a 'race' set.
Thanks.
EDIT....is it $395 / 2 + $20
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
