  • 3 weeks later...
  • Replies 218
Would you ship to the UK? As my R32 GTR is wearing out the tyres on the outer edge which i believe is due to the toe or camber and im uncertain if the standard setup is adjustable? Therefore im hoping this can correct the problem?
  • 6 months later...
Righto ladies
Anyway that last group buy actually cost the supplier money so I have asked again to revise the price to make it worth his while
The last one most people were happy, some people requested additional camber (eg ability to make them shorter)
I have requested if we get 10 people that they make them slightly thicker (stronger) and for additional camber adjustment.
Please not there is only so much you can do so if you want the ultimate camber solution give me a bell (involves mods to your sub frame)
We need ten orders, price is $550
I won’t f**k everyone around buy saying they will be ready in a week. So I am going to say once we have ten orders it will be three months
If it turns out quicker then so be it, I may also put up new group buy thread
Basically let’s say 250 up front then 320 including delivery when they are ready
bank details peter carruthers
bsb 112-879
acc 428 965 807
people who want in below (only 9 to go before we order)
1 fatz
2
3
4
5
6
7
8
9
10
Potential
godzilla32
josh type x
endless
sbr
I will most likely be cancelling my interest. I am getting some R33 LCA's and already have adjustable bushes, so I'm hoping that will give me sufficient camber.
1 fatz
2 sbr
3 willis
4 sav man
5 endless
6
7
8
9
10
still need 5 people
to help generate additional interest perhaps we should make a new thread like you suggested earlier. or just change the topic name so that people know it's round 2 ;)
-4 should be achievable with this batch of arms? :)
Edited by Willis
  • 4 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
