R32 GTR and R33 GTR stock ecus are different, 2 injectors are switched at the loom plug and the R32 GTR doesn't have VCT. So I'm wondering if the R32 GTR version of the PFC will switch the injectors automatically and have VCT working?
as the topic states. im after buying a pfc. but its for a r32 gtr. the guy says that r32 and r33 are the same.
just wondering if thats true,and thought id ask some of the skyline experts on here.
thanks chris.
Forget the PFC, get a Vipec Plug-in!
hello
BNR32 and BCNR33 PowerFC are the same unit, same model, same code etc.
The BNR32 and BCNR33 differences are airflow meter ramp and 02 sensor control.
Depending on which car you plug this model PowerFC into, you need to adjust ETC, FUNCTION SELECT, 02 SENSOR REG
and select the correct Airflow meter from the Airflow meter menu under SETTING, AIRFLOW
the rest is the same, same logic, same loom, same plug, same wiring, same hand controller etc
hello
so basically i can fit the r32 pfc to my r33 gtr. and it will be ok ?
like i dont want to pay all this money and then find out it cant be tuned correctly by the tuner. and have to pay the $400 still
i just want to know. as it will save me money and alot of time
cheers chris.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
