hey mate, i'm after a roadworthy windscreen, front seatbelts, rear discs and heater core.
pm with prices if you have any of them and i will pick up asap
cheers
  • Replies 47
u got front indicators?
have front left indicator
Are they GTR ones or normal gtst ones.
stock projector gtst
dude put up pics ffs
of wat, u dnt know what stock gtst parts look like?
Im after the plastik surround for around the Climate/CD/Ashtrey/Gear Stick if its available and the clips aren't broken, oh and the ashtrey itself
nope broken
Are the front indicators the stock gtst ones?
yes
cheers
windscreen is brand new, have front seat belts and rear discs and heater core
pm sent
ok guys,
stripping my r32 gtst
anything u want is up for grabs including a few after market things
orig no holes NA boot $150
jic coilovers, perfect condition, height adjustable only $650
just jap adjustable lower control arms $300
half cage $sold
gtr mock up bonnet $sold
gtr front bar with garage saurus front lip and n1 vents,$650 have N1 reo aswel for an extra $100
mint front guards $150 pair or $80 each
passenger seat $50
mint centre dash vents $30
all interior plastiks
5 stud conversion $600
rb20 motor 160k kms, any test welcome car is still running $500
5 speed manual conversion with gbox, clutch(heavy duty), flywheel, tail shaft, pedals, centre console $750
doors with glass $100 each or $180 for both
mint pair of projector headlights $150
tail lights $80
20mm rear wide body guards $250
anything else u think of just let me know ill tell u if i got it
wanting rear quater glass surrounds both sides if not broken, how much please. are the front gaurds price for both $250 ?
gtr front bar with garage saurus front lip and n1 vents $650, also have the n1 reo for an extra $100
Hey mate.
I'm interested in these things. Also the left indicator if you still have it.
Where are you located?
thanks,
Russ
0421332860
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
