Hey all,
I'm going to have a dyno evening at R.E.Customs on Wed June 3rd from 7:30pm which any other Melb based R35 owners are welcome to attend.
We'll be doing a few different dyno runs on the night showing what the R35 makes power-wise both dead stock, then with the additon of a mid-pipe and then finally we'll have the long awaited play with the Cobb Tuning software which will be available for both JDM and ADM cars by then.
Location details can be found here - http://www.recustoms.com.au/Contact
So I hope we can get a few of the local cars together - should be an interesting night. :nyaanyaa:
https://www.sau.com.au/forums/topic/271001-melbourne-r35-dyno-night/
Private Event?
Is this for R35 GTR owners only?
Can I come and watch / take photos? I am not dyno'ing my car.
Unless Tim GTR (Alex) has received his white R35 GTR from Dutton already and I can come in that LOL! :nyaanyaa:
Private Event?
i think he has mate, quite sure its gone from there
Ah really!?
Just called him and said he does not have it, Dutton could have sold it to someone else..?
I Don't know...
+ Alex has got a few cars to push...
Ah well next time.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
