  • Replies 340
woulsa come if i saw this. got drunken sightly with mates
edit : was answering jez
Man, you missed out on the best night EVER. Started off at a house party then went to the city. Loft was actually good for once. Sooo many hot girls and they were all over everyone.
Got a lift home from this chick with the mandatory Maccas run on the way home.
yeah i was hanging for a kebab tonight.. settles for larpoghetta :P haha
Who has joined SEI forums here?
haha im will join... im just waiting for the right moment to do it :P
There's about 20 SAU members on there already. If everyone actually started talking on there then it could actually be good :D
Meets are always big, but forums are dead a lot of the time.
lol when you said that, i went over and checked.
last post was 2hours old haha woah fully active brah !
LOL that IS active for SEI. We've had dry spells that last like 10 days.
Me and Chad used to be the only ones that post but now Basti is getting active so everyone else is jumping onboard :P
I'm satisfied with the meet side of things, but the forum needs more topics to get the ball rolling.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
