hey guys
does anyone know where i can buy Stanless steel Sheets in melbourne? dont need alot just to make a catch can + surge tank.
coz where ever i ask they sell it by 2.5m L x 2m H range from 1mm to 3mm thick
cheers
bill
https://www.sau.com.au/forums/topic/271358-where-to-buy-stanless-steel-sheet/
  • 1 month later...
  • 1 month later...
Scrap metal is a good bet.
Last time I bought sheet stainless it was $1 / kg.
Otherwise Midway metals have been the most cost effective for tube when I have bought it.
http://www.midwaymetals.com.au/
Cheers
Wilbo
$1 a kg i doubt it very very much!! I used to work for an aluminium supplier and we also sold stainless to some customers and i can tell you that it would cost more 10 bucks for a 1200x2400x1.6 sheet. More looking at something like 130 bucks of the top of my head
  • 4 weeks later...
I always find it tough to find good cheap suppliers of metal that are willing to sell small amounts. But that's understandable.
For exhaust bend/flanges etc i used dumperking.
http://www.dkne.com.au/
For pipe/sheet/rod etc i use steel solutions... they're really handy!
http://www.steelsolutions.com.au/
I haven't found a good alloy/stainless joint yet, so let me know if you find one lol
  • 3 months later...
you can use alliminum sheets, i used them, u can buy them at bunnings, small sheets around $50, cheapp, they got thick and thin, lots of types. good luck
  • 4 years later...
Considering he was actually looking for STANLESS steel, not stainless steel; the spam link will be useless to him.
I will admit to wishing all of my steel is completely Stan free; Stan has always been a bit of a dick.
hey please check below some Good cheap suppliers of metal..
For Bend and flanges
http://www.simplexfittings.com/
for pipe and round bars
http://www.piyush-steel.com/
and for round bars and forged fittings
http://www.kalpindustries.com/
i want to find some aisi 4130 graders supplier so if u find please let me know...
  • 8 months later...
  • 4 weeks later...
  • 4 months later...
  • 1 month later...
For Stainless Steel, Carbon steel & Alloy steel Products Supplier check
http://www.kalikun-steel.com http://www.pioneerforge.net & http://www.neoimpex.net
https://www.kalikundsteel.com
Edited by rathinfotech
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
