Just had my O2 sensors replaced and my R32 GTR runs much better!
During cruise and light throttle the car is more responsive and quieter! I no longer have to down shift to go up small grades and the fuel economy is better. I should have done it sooner!
About a month ago I took my car out to Hills Motorsports to have them run it on the dyno. Before we started, they hooked up the diagnostic tool and found my rear O2 sensor was dead, and the front was not responding very well. At R32 GTR owners know, the Titania sensors are expensive. I shopped around and found Kudos Motorsports had the best price on 2 new sensors. I gave them my info and received the O2 sensors within a few days. I took my car back out to Hills Motorsports and they installed them for me. Driving away from the shop I noticed an immediate improvement in the throttle response during light throttle. A side note, the black on the back of my white car from the exhaust has reduced considerably.
Thanks Hills Motorsports and Kudos Motorsports! I would recommend using both of these businesses!
https://www.sau.com.au/forums/topic/271646-o2-sensors-replaced/
To talk the the factory ECU you need a CONSULT cable and software for your laptop. It will show what the sensors are displaying and from that you can deduce their condition. I have the PLMS consult cable. It works.
http://www.plmsdevelopments.com/consult_if.shtml
yup, i have the consult cable + software but didnt check o2 sensors prior to swapping to PFC, do u know if PFC picks up faulty sensors at all?
Check paulr33's PFC faq;
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
I haven't checked the km's per tank yet... I do know that from Tuesday to Tuesday the petrol gage is down on empty. This week it is on a quarter tank. (Not scientific, I know.) The exhaust sound was louder and you could tell it was rich. Now it runs smoother and the exhaust note is crisper. On any slight uphill I would have to down shift. Now it has some power down low so you can just push on the accelerator a little and it picks up speed. My wife even noticed the difference!
The change is significant if your O2 sensors are bad. Because they are so expensive, have them checked first!
Mark out at Hills Motorsports in Castle Hill is very good.
  • 1 month later...
i've been fairly interested in this thread.
My O2 sensors on my 32 GTR went bust when my turbo blew and obsiously broke the sensor.
since then i got the turbos replaced to new ones, which are the 2860-5's and because the sensor was buggered the car would run like a real pig when they were plugged in. so i unplugged them. then a week later i spun a bearing!
i know bad luck hey!
since that i got a motor rebuild, forgies, new crank, race bearings, thicker head gasket,etc
but didnt replace the O2 sensors, they've only gotten installed today, but for about a month of not having them plugged in on the new motor the car has been runing fine.
getting around 15L/100km which isnt too bad, but that has been conservative driving.
going to pick it up today,
will post again to let you guys know if i notice any difference.
You can even use a O2 Sensor to test it..
On a cruise in 5th gear doing around 60km/h A/F ratio should be near stoich (14.7) as the closed loop circuitry should trim the fuel down so it leans out, if it's running HEAPS rich you know your O2 is dead.
PFC users
ETC, SENSOR SW CHECK
look at 02-1 and 02-2
these are your 02 sensors
they should blip up and down when you tap the throttle
if they are toast they will show 0.00 or hardly move
and the sensor name may become highlighted in black background if its shagged/unplugged
the O2 sensors didnt make much difference to overall power, but it definitely does feel a lot nicer to cruise around.
my fuel ecconomy has improved heaps too, i did a bit of a country drive on the weekend and i've still got a 1/4 left in the tank (yes, i know its a guage reading which isnt accurate at all) but i've done 450+ kms
before i would struggle to get 400kms out of a full tank, i know the country drive would've helped.
the car seems to be a little more responsive at low revs too when its off boost.
just feels and sounds more crisp
i got genuine ones, and i'd say they're well worth the money!
i dont think my mechanic took too long to do it?
he didnt charge me any labour though, because it was supposed to be done with my build but the sensors didnt come in.
i would assume it would be a bit of a pain, just like doing most work in the cramped engine bay of a GTR.
i think you might need a special tool to be able to undo it?
not 100% sure??
Brez
they shouldn't alter power output.
there is a special tool, 02 sensor removal tool
its bascially an open ended socket so you can slide it over the sensor and it doesnt clash with the plug
i think its about $30 from repco, without it = dont bother
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
