Ouch... More delays, huh? :starwars:
Oh, I'm seeing Falcons in that Breeze colour everywhere now!
+1
Had a mate roll up in his XR6t yesterday... couldn't help but think "Yup. An R34 front-ended C34 will look ace in that colour"
ah that sucks to hear mate, there are no doubt places that rent out booths to use over your way? i know there are some over here
There is only 2 hire booths in Brisbane. $90-100 per hour plus bake time. So by the time you roll in, mask up and paint and bake it is around 4-5 hours :( Plus the painters cost
Worked on the car all weekend, meet with the painter/mate yesterday arvo everything was planned to paint it today. Get a text this morning at 6.20am, sorry mate can not do. I was furious :)
Spoke with my brother in law today who is a panel beater. His painter is going to do it this Sunday for $200. He sounds cheap, but he painted a mustang recently which got voted Australia's best. So it should could up great if my prep work is any good. Fingers crossed. :)
Fitted new sydneykids bilsteins today. The rear can only go to 340mm, they hit the tyres. Have 5 more grooves to go. The fronts have a few more grooves to go but the bottom platform hits the suspension arms, even after putting a 4mm deep groove in the bottom spring platform.
Should just leave the boody thing standard!!
Looking at new wheels. I am a bit over the R34 rims
Maybe these in 19x8.5 or 19x9's
These are 3 peice that way I can play around with offsets and not have to use spacers on the front.
With the R34 front being wider, I need to run approx 20mm wider offset than the rears to fill the guards.
With a type A or B disk upfront and C disk on the rear, should be able to keep the same dish F & R
Was thinking gold Rays GT-c's but the price is up around $4500 for rims :P
^^^ i do love the look of black wheels but am of the opinion that if you are going to spend the big dollars on gorgeous wheels (the 2 option you posted are prime examples) why would you want to hide them by blacking them out?
I agree!
If we were all made of money, how about Volk RE30's or CE28N's? Those would be my two picks.
I am a lover of 2/3 peice rims. Does not matter too much on center colour, but need the polished rim whit as much dish as possible.
That is why I am looking at modular wheels so I can get my offsets right.
I think most have seen my previous R33, ford blueprint with gold rims. plus 15 years ago ta22 celica in ford everglad green with gold B45's in a massive 15x6 with 195 tyres. That was huge back then LOL
Would also like a set of Duluck six spokes, but they have stopped making them
Picked up a pair of EVO 8 Recaro's yesterday for the fronts.
Just need to make them fit the bride rails.
Will be using series 2 manual back seat and door trims I have lying around.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
