FS:
- carbon gtr vented bonnet mint condition, only trial fitted $700
- gtr cusco coilovers, full set, mint condition, seen 2000kms only, fully adjustable $1200
- full bolt in cage, cross bar and side intrusion bars, this is a serious cage $900
- 3 1/2 inch stainless catback exhuast with twin flutes, no mufflers sounds decent $500
- r33 rear 5 stud + brakes + hand brake cables $400
- 2 way mechanical diff cusco, mint conditon $700
- non hicas rear cradle with gtr sway bar and alloy cradle bushes $250
- rb OS Giken twin plate clutch + flywheel combo, plenty of meat left $600
- ICS rear camber arms $100
- cusco rear toe arms $150
- OMP dished steering wheel with boss kit $250
- Wide body front and rear fibreglass guards, only trial fitted, not painted $400
- full BN kit, front, rear, side skirts never fitted, not painted $600
- r32 shell, call for details $500
all prices are firm, can negotiate if buying a few bits
Located: SA
Contact: ph. 0409078708
Pics: can send pics to your phone, only request if your seriously interested, these are all quality parts
Edited by peripheral port
https://www.sau.com.au/forums/topic/271816-fs-r32-wrecking-unfinished-project/
Hi Champ,
Im in sydney and interested in you rear camber and toe arms are they still for sale? if so please tel me the price to ship to sydney. I have tried to call you a few times but your phone was off.
Spiro
0414509399
i dont mind posting items, as long as its organised by the buyer, i can drop off and package up the parts if needed.
the r32 shell is rolling at the front, not at the back, but can be if you buy the rear cradle and 5 stud with it, not much interior just basics like dash and loom. no compliance, suitable for track use. will take $400 for the shell.
  • 1 month later...
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
