Hey All
I have been searching for about 4 hours now. I think I went through nearly every topic posted on the entire website. Well, that may be a small exageration on my part. I am looking to upgrade/replace the turbo I currently have in my car and I want to know the quickest/easiest way of doing so. Also, the cheapest.
What I want is a turbo that will just bolt straight on to the existing fittings and lines. I have no idea which one will do the job, I'm guessing someone out there will know exactly which one it is.
My car is a 1995 R33 GTS-T.
Please help, I think my turbo is about to die.
Cheers
Tony
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/
Totally depends on
1. Budget
2. Power aim/use of the car
Cheapest isnt always the best, you must understand and accept this as part of your decision.
Once you do that - follow this
1. Read the RB25 dyno sticky thread.
2. Find turbo's that fit your power goal
3. Search with those turbo ID's
4. You will see costs, problems and so on.
There are many many turbo's to choose from. Cheaper ones generally have poor response with OK peak power.
More expensive options generally have great response and great peak power making a very good overall setup.
Also bear in mind larger turbos lead too... and in some cases REQUIRE the following in order of importance
1. Larger Exhaust/Cat
2. Better ECU to tune/make USE of the turbo (no point upgrading turbo on a stock ECU)
3. Larger AFM
4. Larger injectors
So please take the time to address the above points yourself otherwise no-one is really going to be able to help you.
Overall in my opinion you dont really understand whats involved (refer to above points about other parts), so a simple replacement of the stock turbo with another one would be the best option. If your car is stock now and you want to replace the turbo - you have to spend at LEAST another $2,500 to actually make the upgrade any valuble use.
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4621241
My apologies, I must have described the whole situation very poorly. All I really want to do is buy a new turbo for my car. I'm not looking for power gains, nor am I looking to lose any power. From the research that I have done, mainly with Garrett Turbos, I have found that they do require for new oil and water lines.
I basically want a new turbo to replace the one that I have. Just one that will bolt straight on with little or no modifications at all.
I hope that makes a bit more sense now.
Cheers
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4621258
What mods do you have now though?
And im not sure where you have read that information about Garrett turbos, a large portion of Garrett turbos in a similar frame size are a bolt on affair that use the factory lines. Same as HKS turbos (which are Garretts with a badge and/or minor toying)
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4621276
This will be your best bet for what you are describing.
Yep.
If you wanted to spend more for the sake of reliability, you could get your current turbo rebuilt. Or even by a rooted one and get that rebuilt, so your car isnt off the road for too long.
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4621615
Hi again
The mods that I currently have are:
3 1/2" cat back exhaust (about to purchase a 3" dump pipe)
Large FMIC
Apexi Pod Filter
Aftermarket Coil Packs
GFB Boost Controller
What makes me think that the turbo is going to die, is the fact that it has been in the car for 14 years now and I think that it is dirty as hell or on the way out. It still manages to boost at around 12PSI though. So I could be wrong.
My other plan was to remove it and give it a massive clean and have it tested to see how bad, or how good, it really is. I was reading the workshop manual that I have and it hints at the point of black soot covering the rear bumper. Apparently it is caused by excessive carbon and sludge build up in the exhaust turbine. Which is why I was thinking of just cleaning it out.
I was thinking about having the current turbo recon'd, but then my missus said to me that I may as well buy a new one.
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4621845
If it ain't broke, don't fix it.
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4622056
Except your talking about a stock rb25 turbo that are prone to disintegrating when boost is above standard (he states he is running at 12psi)
Our stupid turbines are ceramic bonded to steal....
Here are a couple options.
GCG rebuilt with Garrett components (about $2000) chasers motorworks also offer a similar service
HKS GT-RS kit. (about $3500 imported from japan or add another 1k or so if you buy locally)
and thats about where it ends before your looking at new manifold, dump pipe, etc.
Cheers
Camden
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4622091
No, that will be due to the fact you have a stock ECU.
The stock ECU is fuelling up hard under load/boost, and this will be causing the build up on the rear bumper.
The exhaust housing/turbine is over 500 degree's... there wont be excessive build up going on there
https://www.sau.com.au/forums/topic/272101-bolt-on-turbo/#findComment-4622231
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
