  • Replies 40
jabtronic----> Hey thanks for putting that up mate !
I am actually located at Terrigal, 1 Hour north of Sydney. Because I am a business, I'm not allowed to organise a group buy here on Skylines Australia, due to forum rules.
If you guys want to organise one though, and the forum moderators approve it, I am happy to supply the Turbo Timers.
I just want to abide by the forum rules.
You may notice that my everyday price on the Timers you want are actually cheaper than any other Australian Distributer. (even with their "Group buy discount")
Kristian
[email protected]
www.JapaneseImportParts.com
G'day Kristian,
Thank you for your assistance. I have sent you an email regarding further information.
As for the rest of you guys here, as I was the first to open my mouth in trying to organise this, I don't mind investigating further to get us all the best deal.
I will find out what prices for what brand and publish them here. We can then discuss it and take it from there. What do you all think?
Cheers!
Yeah Japanese Import Parts has pretty good prices, I hope a mod will approve a group buy.
I've been doing I bit of price comparing for a number of different parts and pretty much all of Japanese Import Parts prices are the cheapest I can find in Australia on the net. ;)
Keep it up Kristian :)
Ok Guys, it seems this has been approved by the moderators as the post is now in the group buy section !!
I am able to supply the APEXi Slimline Turbo timer for $128 each , regardles of how many people decide to get one.
I am here to answer questions, and if you guys see anything else on www.JapaneseImportParts.com that you would like, just let me know.
Shipping is flat rate of $8 anywhere in Australia via insured parcel post (Australia Post ).
The $$ obviously come to me, and as I am a fully registered business, and people here on the forums know me and the service I provide, I'd say your money is safe. Money order, cheque or direct deposit is ok.
G'day Kristian,
THanks again for your help. Well given that your price does not require a group buy, then I guess anybody who is interested in this one, please contact Kristian directly. This will avoid any unnecessary handling of any moneies that need to be transferred.
Kristian, can I ask you, given that there has also been some interest in other turbo timers. eg Greddy, HKS etc etc....can you please advise on how much you can sell these for, including the harness. Oh and one last thing. How long are these prices going to last for the Apexi tt's I'll get one regardless, just want to know if you have anything else in stock.
Thanks.
Originally posted by king_kw13
Get the Blitz DTT. That got digital boost gauge and also auto timer for boost and also travel time :)
what do they look like ? and how much to they go for ?
KingKW.........phuck man, do you ever work!!! :) How much did you pay for yours. My understanding that these are pretty pricy. Looking at close to $200, is that right???
Kristian, can you possibly help us out here as well?
Thanks!
Scotty--->The APEXi TT will be at the lower price untill 15th November 2003, then back to $145.
All harnesses are $30 each.
All other turbo timers are listed on my website, and if you want them any lower, a group buy will have to be organised. As stated before, the prices are pretty low compared to other Australian businesses.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
