That looks f**king horriable... Typical NSW style build lol
actually it was from Florida, first 2009 GTR to be hacked up for a custom build,
notice the sign behind the car to the left
hahahahahah
...feel the love :)
Don't get me wrong, you have some of the best engine builder/tuner shops in Australia in Sydney such as PAC performance, Maatouks, CRD etc etc list goes on... But you also have alot of straight up drop kicks that build the ugliest fpos' I have ever laid eyes on especially sex spec on imports - epic failure lol
Edited by Weezy
due to the rash of un-awesome crap in this thread i give you a quad turbo V12
Configuration : V 12 cylinders
Capacity : 6715 cc (89 x 90 mm)
Valve actuation : 4 over head camshafts, 48 valves
Forced induction : 4 turbochargers
Max. power : 1000 horsepower
Max. torque : Over 1000 Nm
Clutch : Multiplate
Gearbox : 6 speed sequential
that lives in this :D
Chassis : Multipoint rollcage welded to the shell
Suspensions : Double whishbones, KW adjustable shocks
Brakes : 381 mm carbon fiber discs, 6 piston calipers
Wheels : 13 x 18 magnesium
Tires : 345/35-18
Length : 4650 mm
Width : 1910 mm
Height : 1215 mm
Weight : 1000 Kg
0 to 60 mph : 3 seconds
Quarter mile : 9 seconds
Top speed : 220 mph
When did this thread become the daily fix of projectile vomit? :)
agreed!
thank you very much Carl!
awesome indeed
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
