wonder how long till turbo EJ25s start appearing in them?
Couple months maybe.
i wonder which d1 team will be the first to put a 2j in one?
Which American will be the first to put an LSX in it.
An in-depth look
http://www.motoiq.com/magazine_articles/articletype/articleview/articleid/2279/86-under-the-skin-technical-details-on-the-toyotasubaruscion-86gt-86fr-sbrz.aspx
Chief Engineer Tetsuya Tada was quoted saying
“There is a Toyota standard for designing new cars. This standard was to a large extent ignored. Why did we do this? There are cars that are accepted by a lot of people. Practical cars that are easy to drive and that do not break easily. These are standard Toyota cars. The 86 is not a car like that. We had to change our design approach for this car. We may have to do this again for other cars.
It is impossible to develop a sports car that appeals to everybody. If you try to please everybody, the car would be half-baked for everybody, and not particularly good for anybody. This car is not developed by a committee, or by consensus.”
That strut brace looks like they pulled it off a kids backyard play set!
Unfortunately the stud pattern is Subaru, 5x100
If Nissan had concrete plans to sell a small, affordable, light weight, RWD sports car, I have no doubt we'd be talking about that...
... But as it stands...
:P
what do you expect to get out of a 2.0L N/A boxer? The car is aimed primarily at handling and efficiency rather than all out power. Put a big heavy turbo engine in and say cya later to the low centre of gravity and hello to $50k + price
In just a short few days, the GReddy team secretly developed a prototype Type-S coil-over suspension, big brake kit, and a Spectrum Elite SE exhaust system for the FR-S. The team also installed high performance 19" Volk Racing G12 wheels, Hankook V12 tires and a custom "F-Sport" inspired black and blue interior.
http://greddy-usa.blogspot.com/2011/12/1st-modified-scion-fr-s-is-greddy-tuned.html
I think it didn't need a turbo. But I would have liked to see s2000 like power. 180ish kw at the motor would have been enough.
But hey, with compression like that. Your probably be only an intake,exhaust,ecu and e85 away from it
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
