I found something very scary on the inside of the right rear tyre today:
lucky i just happened to be looking under the car- it was not making any funny sounds or any other warning that it could have let go at any moment!!! The tear had gone almost right around the tyre- 4-5 inches before it could have been very bad ending (especially if doing 110kms/hour)... Looks to have slighly damaged the rim too, but that will be an easy fix i imagine
But i look on the brightside- whilst the tyre is being replaced i can look even more pimpin :(
widebody kit anyone? haha
https://www.sau.com.au/forums/topic/272496-fudged-tyre-the-new-bling/
looks like there's a screw in the tyre in the first pic so i'd say low pressure+the mad camber wear! which i say would be from towing heavy car trailers... that's the kind of thing that would make it split like that as opposed to just bursting.
btw, they look like a maxxis MA-V1 or an early pattern sumitomo HTR, for those of you playing at home
D.
dont be fooled this happened to both my rear tyres and they blew out at 110 km/h both 50m apart Lucky i was i the middle of moving house and had my stockies in the back of the car. I still dont know what caused it and i could not find any polish marks in the wheel arch when they did my breaks even the guys at brakes plus said they could not find any point of contact. i had 19's on and @ $350 a tyre i thought to hell with that and put my stockies back on. havn't had any issues with it since. :P
One idea i did have is that when doing hi-way travle and you hit a sag or dip in the road "maybe" the top part of your rear shock grazes the tyre. but again i cannot be sure. as i couldnt find any rubber under the wheel arch.
pretty sure i had the same tyres as you "falkens" and i think mine were 245/??-R19
I will take some picks when i get home and show you its exactly the same thing.
Edited by loymclure
Yeah I had the same issues as well with my last set of tyres...I had Falkens on mine...but the tyres had about 75% tread when I brought the car last year.
I'm guess it's comes down to tread wear. Doesn't AWD skylines/stageas have a issue with inside tread wear?? (damn...which reminds me, I need to change those blasted castor arm bushes again)
my bad, should have quoted post above yours
brand doesn't really make a difference with this kind of thing anyway, i've seen it with just about every brand
D.
Edited by pintaline
well spotted- nail in tyre which caused slow leak- driving on deflated tyres for to long= fudged tyre...
Pictures as promised, i dunno about you guys but that dont look like any normal Stagea issue ware of a tyre. any way it may not be related, but it could be an issue? The damage is way worse then the OP's but i guess i wasn't lucky enough to find it before they blew.
Or it could be the Commode problem of when heavily loaded the tyre comes into intimate contact with the rear suspension...
Knew someone with a VY Ute who put on new tyres before relocating to Melbourne. Put his entire life in the rear tray, and by the time he got to Mel had worn parts of the tyre down to the canvas...
All right.... Past two days my mum has borrowed the stag for carting some stuff to and from houses (shes an interior decerator or whatever).... Ive always been hesitant about lending it to her after I got new wheels.... anyway today phone rings about an hour after she took if from home and she doesnt usually call me during the day, expecting turbo timer questions ect she says Im very sorry but ive damaged the car. So shes rashed the f**k out of the front left wheel doing a U turn. Shes all good and going to help pay for it but man its a real PITA!!!
At least this wheel wasnt one of the mint un rashed ones .. :blink:
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
