jus spent the last hour on search trying to figure this out and this wat i make of it....pleases correct me if im wrong....
there are 4 cradle bushes which need cradle to b dropped and bushes pressed in/out. alot of work and labour.
u can buy solid alloy bush cradle inserts x 8 which stiffen rear up but sum say gets noisy sum say not. cradle stays on
then theres pineapples x4 which depending on how its mounted promotes traction/grip or drift. cradle stays on.
how do u know which option to go for and wat u need. im after grip, reduce tramping and general upgrade of worn bushes. i found a nice basic diagram showing where pineapples go for different results.
sorry for being 'slow' but jus after a simple breakdown of the whole thing.
then also u can get rear diff bushes x4.
thanx
https://www.sau.com.au/forums/topic/272740-info-on-rear-cradle-bushes-r32-gtst/
get the alloy ones i did im im very happy for it
the noise factor is so small ill bet 5 that you probably will never notice it mate
but you will notice the car is heaps better to drive
did u replace the inner bushes, or just the subframe-chassis bushes? the real NVM comes from when u solid mount the inner bushes as well, which a lot of people dont.
for a daily i would stick with Urethane, especially if ur running a lot of rubber around the place and softish suspension. there are usually other causes to the axle tramp before ur subframe bushes.
What do you mean by "worn"? The rear subframe bushes are silicone filled, they need replacing when they burst and the silicone starts dripping out. If there is no silicone leak then they don't need replacing. In which case pineapples are the go as you can change the rear subframe angle, something R32's really need.
Cheers
Gary
i solid mounted the lot and im very happy
including solid uretane for the diff which means you ca hear the diff but its unrelated
come and have a drive of mine if your local and see for your self
isnt the diff solid anyway? lol
may be different on GTR's, i know R32 GTS-t's are solid, R33 GTS-t's have a bush on the front mount.
i dont care a great deal about NVM so its not something i look a lot into lol
when i got the car it was pretty much bone stock as well, but it had been converted to a manual, and a fairly budget job as well, maybe they came out when they did the conversion :S
i run some urethane bushes i made up with my R33 diff at the front mounts as it needs to be spaced down, but nothing for the 32 diff.
so the cradle bushes only need changing if they leak... ok ... mine arnt leaking so that answers that question
next is the difference between the cradle inserts and pineapples. which one applies when ?? thanx for all the replies....
u have bushes IN the subframe, where the bolts go through which holds the subframe to the chassis, then u have bushes that sit between the subframe and the chassis. the ones that sit in between the subframe and chassis "align" ur subframe, so u can change the tilt, which changes the amount of squat u get.
The cradle bushes near the doors are silicone filled, if they're stuffed its fairly obvious, the rear ones are solid rubber. When I replace my cradle bushes the front were stuffed but the rears were still ok, no tears in the rubber and looked good. It is harder to tell if the rears are gone. I replaced all four and even though only the fronts were stuffed it was noticeable under hard acceleration out of corners that there was a positive difference. Didn't notice it at all when driving normally though. If the cars a long term proposition then I would do the cradle bushes if not then you would probably get away with the pineapples.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
