What condition are your pads in? If you have plenty of meat left on them, I'd say you'd be fine, definately flush the brake fluid though and check the pressures in your tires
ah k rears are good front is low and theres bit (large) of a lip on the rotor, friend said it wouldn't need to be changed (rotors) but i really have no idea
Id start with tyre pressures around 26psi as they will raise to over 40 when hot. Otherwise you'll be skidding like a mofo.
I'll go high like suggested and let air out if i need to.. and go get pressure checker thing.. do we need to bring the receipt with us? cos i have no clue where I've put mine haha
  • Replies 383
^^ that article is all good and well but he still needs the 'G Sensor'
Not necesarily, the computer just needs a voltage input which theoretically could be from any source - not sure what else would go wrong though... :D
Is all beyond my skills to be honest but would be interesting to find the answer either way.
receipt on the day is not necessary, but if your name's not on our list, you won't be able to drive :lol:
you'll need to bring your driver's licence though.
Ok i know you have told them to resend the reciept to my email but checked it today and still no email with the reciept....so i have PMed you
Thanks mate
Oh well i start with 25 psi and my pressures are above 42 psi after i come off from the 5th lap and thats with my Hankoon Venti S1 street tyres 275/35/19.
damn those are wide tires.. had 235(F) & 255® b4, but gone to 235(F) & 245®
just about to order some new engine mounts and some acre brake pads. hopefully they get here before tuesday.
:EDIT: and 20 minutes later, pads are ordered and paid for, just waiting on a reply from driftshop for the engine mounts. $279 for 2 urethane mounts beats the shit out of $430 for 2 oil filled genuine nissan mounts.
Edited by scandyflick
car overheated on the way to nightshift last night(was driving peacefully). looked down at temp gauge and was like wowzer had to dump the car and wait for a mate.. picked it up and drove it home this morning no problems so i got no idea what to.. do.. oil is fine and coolant is good so :S :EDIT: overflow bottle is empty :S going now to see if i can buy more and top it up
My rims on the GTR are 10.5" wide all around. So 275's front and rear, who says 34GTR's dont have wide guards :(
you not the only 1 with 275s mate :P mine are only 18s though
Edited by Inline 6
hi kim...still no response mate????
i just spoke with Dean and he said that he has emailed it twice now. can you PM me your email address or fax number and i will send it to you myself.
cheers - Kim
cheers - Kim
PMed you before about it but will PM you again
thanks man
there may be some confusion about helmets arising from a recent email from Dean at John Bowe - the original promotion for this event was that helmets were not mandatory. i have just spoken with Dean a few minutes ago and he confirms this, but we agreed that you are welcome to use a helmet for the higher speed sessions in the afternoon.
so helmets are not mandatory required equipment, but you can use one if you have one. Dean sent out an email to this effect while i was on the phone just now.
other than that, please read the receipt / Booking Confirmation that he has emailed you and go through the checklist again.
i'll email/PM everyone details on meeting up in the morning if you want to go up to Mallala with a group. any other problems, please let me know.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
